Charge Motion delete plates?
Old Jun 27, 2009 | 04:05 PM
  #21
06stangGT's Avatar
06stangGT
Originally Posted by DLZ314
What gaskets?
Am I missing something from my kit, I'm about to do my install and I wasn't shipped any gaskets...
Sorry I think I misspoke, I was thinking about the header gaskets . . I don't think there is a gasket for the midpipe
Old Jun 28, 2009 | 01:48 AM
  #22
DLZ314's Avatar
DLZ314
Thank god! Altough, I probably could've used a gasket or two and some more daylight, it got dark before I finished, and I couldn't do a thorough leak check, which my test drive tells me I have. SH*T.
Hey East, how'd your afternoon go?
Old Jun 28, 2009 | 08:31 AM
  #23
East87's Avatar
East87
Well I got it on, but it came with its difficulties haha. Keep in mind, this would be my third time *ever* underneath a car doing modifications of any kind. The first was for my k-member brace, and the second for my MGW shifter.
Anyway, it took me a long time because I broke some clamp spacers...and had trouble in general getting the 4 pieces together before I put it underneath the car. I started by connecting each side together long-ways...as in I put together the whole driver's side first (loosely clamped) in my garage (not under the car), then I put the whole passenger's side together and mated them at the "H" section before I even put anything on the car. With the entire pipe loosely assembled, I clamped the "H" section together (*you can and should use a drop of red loctite on each bolt on this clamp, and ONLY this clamp, as you can disassemble the midpipe without disturbing this clamp in the future*) and tightened a decent amount. Then I attached the midpipe to the rear over-axle pipes and tightened decently. Then I tightened the mid clamps that held the two halves of the pipe together. Then I bolted everything to the stock exhaust manifold. Basically, I progressed from the back of the car to the front.
I left my LoudMouths on initially...If I lived in complete desolation, that setup might be workable. In a neighborhood? Not a chance in hell. Does the o/r H sound good with stock mufflers? Meh, like anything dealing with stock...it could be a LOT better. It's downright quiet at startup, quieter than my LoudMouths on the stock midpipe haha.
I made a thread about it (mostly my frustrations) here: https://mustangforums.com/forum/2005...ome-on-in.html
I'm very happy I got the pipe in (and generally pleased with the results), and it'll only be a matter of time before I get my Stingers, and the exhaust sounds AWESOME again.
/snip
Edit: I have a big exhaust leak...f#&%!
What do I do about the leak besides tighten bolts?
Old Jun 28, 2009 | 10:53 AM
  #24
DLZ314's Avatar
DLZ314
Yikes, East I feel you pain, I had an almost identical situation, putting up and taking down the pipe multiple times, until I decided that my first attempt had indeed been correct.
When I say I have a leak I should I hope I have a leak, because I don't like my sound at all. I'm headed back under the car now. THe Bassani is a five piece mid-pipe with all slip fits, I'm thinking I may have left a gap, I didn't finnish my install until it was dark out after-all......
Old Jun 28, 2009 | 03:15 PM
  #25
06stangGT's Avatar
06stangGT
Well keep me updated with the install, my pypes off road H comes early this week !
Old Jun 28, 2009 | 04:09 PM
  #26
East87's Avatar
East87
Put the inserts in and I'm still getting some kind of leak from somewhere...I have a feeling this is going to be a never-ending battle until I fork over way too much money...
Old Jun 29, 2009 | 11:44 AM
  #27
DLZ314's Avatar
DLZ314
I got back under there and found a leak, tighten it up and it sounds much better. I think there might still be a tiny leak somewhere else though. Bummer. My bigger frustration now is getting my mufflers to line up, I had to loosen every pipe connector to install the mid and now my mufflers are way out of line.
That said I'm biting the bullet and taking it to a shop with a lift so they can line it up and I'll ask them to check for leaks while they've got it on the lift.
Old Jun 30, 2009 | 09:30 AM
  #28
GQ4Life's Avatar
GQ4Life
can I use the charge motion delete plates for direct port meth injection?
i believe NOS port same as meth 1/8 npt
Boostaddict
Lethal Performance
Oct 1, 2015 08:58 AM
Boostaddict
3.7L V6 S550 Tech 2015 - 2017
Oct 1, 2015 08:57 AM
mdg
Oct 1, 2015 07:04 AM
bradleyb
California Regional Chapter
Oct 1, 2015 01:02 AM
