another throttle body thread
http://www.brenspeed.com/1763.html
So I've done a bit of research on these and as far as i thought, they were a bad idea. So many negative and mixed inputs steered me away from getting one.
So last night I was at a local cruise spot and ran into a friend I havent seen in a while, last time I saw his car he was bone stock... now he's got the C&L intake with the BBK 62mm throttle body, tuned 93oct through brenspeed, and a set of 3.73's. He has had all of this on for 2 weeks, with no problems.
Should i pull the trigger on this ? Or wait a little longer and wait and see how this works on his car ? I have the JLT III , and the steeda UDP in addition to the 3.73's and the 93 brenspeed tune. Would the brand of intake make a difference that could cause negative affects on my car and not his ?
Thanks
Thanks
An aftermarket TB provides little to no gain on a NA S197. I'd stay away from them simply due to the overwhelming # of forum members that have had issues with the install. Assuming the install goes ok, I still truly doubt there'd be any SOP noticeable gains.
thanks for the reply, I do agree about the power gains, however I have heard that doing this mod with others like the pulleys, and delete plates, you can get a good little gain...?
Thanks
Thanks
he can because his luck is currently going his way.
I think they got a bad rep from alot of people. I ran one for a long time with no problems whatsoever, and I installed one in another car that is still running it (6 months now) no problem. You just got to make sure you switch the parts over right, its easy if your good with things like that (small mechanicals and prewinding a spring as you set it,) and was probably the cause of so many bad reviews.
I would still be running it now if I wasnt told it would not fit on my Saleen supercharger without milling some metal off (I still want to see for myself, looked good to me.) But dont let others steer you out if its something you want to do, just take care while transfering the parts from your old throttle body. Its not a huge difference, but the more air you move through it, the more you will benifit from those larger openings.
Part of the reason for not NEEDING an aftermarket TB is because the stock TB passes as much air as an NA'd (or un-modded heavily internally) GT can handle. Having a bigger TB does not equate to more power if the engine can't suck the additional air.
One of the issues I heard with the aftermarket TB's is the voltage setting. But I don't know enough about it to speak intelligently.
I'll all for the mod, I have the GT-500 TB on my car and without a tune and I felt power increase. I have the TB kit from Metco and it came with all the electronics new already installed form Ford. I would recommend the twin 62mm from Ford racing being they have new electronics installed also, and a good dyno tune
BBK sells a throttle body / air intake combo which utilizes original hardware and eletronics (i.e. mass air sensor). I installed, never got a tune and noticed quite a difference, especially around the mid level rpm range. But whatch out; the kit requires that you remove the motor from the stock throttle body and this was not designed as such. It was very difficult due to torq screws and thread lock.
I got a BBK 62mm from a member on here. Install was easy, no problem if you can turn a screw driver and follow instructions. In fact on BBK's site they have a great vid on a GT that takes you through EVERY step on the install. easy.... At first i didn't notice much HP gain, even made a post about it. But after 2 weeks with it installed now, I do feel a bit more seat of the pants hp gain. I think people don't follow instructions and run into issues and post bad comments on things. BBK would not sell something that was having that many issues. The install is very simple but you do need to follow the instructions. Mine runs GREAT and i didn't even do the voltage thing since i do not have the voltage meter to check. I got the BBK since the price was right and it is a mod i wanted since i have a supercharger in line for a future mod. But on a NA with the bolt on mods i have it is a pretty good mod. And it sounds cool, lil air "squeek" kinda like a turbo while going through the gears.. lol
Here is what we did at the shop. The shop already does P&P work on heads and S/C's so we figured.........why the hell not.
Final numbers after install and tune was 289rwhp and 304lbs rwtorque (ambient temp 89deg) not bad for an N/A automatic DD.
