SCT
Old Aug 22, 2009 | 09:21 PM
top00cat's Avatar
top00cat
Default SCT
can you check your air fuel ratio on the SCT x3. I am concerned mine may be running rich
Old Aug 23, 2009 | 12:56 AM
DarkJFMan's Avatar
DarkJFMan
Yes... in a way, hook up your sct to your car and to your laptop and use Livelink to get the information you want.
http://www.sctflash.com/tsaddons.php?type=DL
Old Aug 24, 2009 | 08:18 PM
top00cat's Avatar
top00cat
how did you get your livelink started. I downloaded everything i needed i just cant find any instructions on what to click on and how to get it running
Old Aug 25, 2009 | 06:19 AM
GT John's Avatar
GT John
From the factory, the base fuel table at wot is set to .850 or 12.4 a/f. This is too rich, but is safe.
For best performance the wot a/f should fall between 12.8 and 13.2 for an n/a car. Trial and error.
So, to answer your question the best thing to do is to have the car dyno'd. If you are not happy with the a/f then have the shop adjust the fuel using a tuner.
Old Aug 25, 2009 | 09:39 AM
AmericanSpeed's Avatar
AmericanSpeed
^ to what GT John said, I'm pretty sure that it is only going to tell you what side of the lambda the tune is set on.
Old Aug 25, 2009 | 10:12 AM
geocomp's Avatar
geocomp
I am curious as to how to do this as well. What is the parameter I would monitor to determine the narrow band A/F ratio?
Thrashard340
Oct 15, 2015 11:05 AM
12bigredstang
Sep 24, 2015 05:46 PM
12bigredstang
Sep 24, 2015 10:43 AM
03blackwidow
Sep 20, 2015 02:36 PM
kmad61
Tuner Central
Sep 18, 2015 05:02 PM
