Help needed ...
Old Oct 1, 2009 | 06:43 PM
2006Boss's Avatar
2006Boss
Thumbs down Help needed ...
I'm new here just bought a 2006 Mustang Gt Boss edition with a procharger and intercooler...it also has headers and a full exhaust ...I have changed all fluids to syn and want to change spark plugs and maybe the coils, just because i don't know when plugs were changed...what plug do you guy recommend? Didn't know if I needed a special kind for supercharger. I have heard that whatever it I get it needs to be a one piece plug. Any help would be appreciated.
Old Oct 1, 2009 | 07:22 PM
hammeron's Avatar
hammeron
you probably need to stay with HT0 plugs, which
are one range cooler than stock plugs. post up
some pics of the car when you can.
Old Oct 1, 2009 | 07:48 PM
Stkjock's Avatar
Stkjock
Retired Mod
Autolite HT0 or Brisk (not sure the model off hand) one heat range colder. gap them to .032 if your at 10psi or less boost.
keep the stock coils... no need to change them
btw - There was no "Boss" edition cars.... the dealer just threw some decals on
Old Oct 2, 2009 | 09:22 AM
2006Boss's Avatar
2006Boss
Thanks guys...I posted some up in photo gallery..
Old Oct 2, 2009 | 09:32 AM
hammeron's Avatar
hammeron
looking good and that is one clean
engine bay
Old Oct 2, 2009 | 07:58 PM
2Gils's Avatar
2Gils
You may want to look at this thread. The folks in there all have had some sort of sparkplug issue where the plug comes apart and you cannot remove without special tools.
https://mustangforums.com/forum/4-6l...and-spins.html
Old Oct 5, 2009 | 01:38 PM
impulse GT's Avatar
impulse GT
The Brisk are by far the best set out there. we have installed hundreds of them. We have also been unlucky enough to hav to remove several broken stock plugs on cars that never got the TSB finished. The Brisk arent cheap and you should change them regularly on a blown motor, but worth it even from a dyno perspective.
Etiher way, the ATI units are seriously bad a$$ but get your car to a dyno to verify the fuel trims. Most of the stock kits do not have enough fuel to safely run the cars. Try to stay around 11.0:1 to 11.5:1. Most of our customers needed at least a fuel pump upgrade to keep their cars there on the top end.
send us an e-mail if you have any questions about your set up or if you need any further advice or parts. We've installed just about everything and I own 3 05+ Mustangs myself at different states of total mayhem. Eric@impulsecars.com
Old Oct 6, 2009 | 02:45 PM
2006Boss's Avatar
2006Boss
So I just ordered a set of the Brisk plugs and I will attempt to change myself following the TSB and keep my fingers crossed..I am looking in my area for a good place to have put on a dyno and tuned. The guy I bought it from said he put on dyno and It made 511 to wheels, but I do want to have done to make sure its right..and thanks for the info..
Old Oct 6, 2009 | 05:29 PM
sactown's Avatar
sactown
Damn! 511 to the wheels! How much boost is that thing running?
Old Oct 7, 2009 | 02:13 PM
2006Boss's Avatar
2006Boss
It puts out 10psi ...But like I said guy I bought it from said it did...but I am going to have it put on a dyno myself to see if its right...and have tuned if needed..
