Supercharger Question
Old Apr 26, 2010 | 09:54 AM
Pony123's Avatar
Pony123
Default Supercharger Question
Hello guys i recently bought a V2 Supercharger and have couple of questions
I have a 06 Mustang Gt with 19000 miles.
Im planning on going 400-450 on 8 psi non intercooled.
Do you guys recommend me getting injectors and boost a pump?
Do i need to get injectors and a boost a pump.
What size injectors should i get ?
Thanks for the info
Old Apr 26, 2010 | 12:43 PM
nite's Avatar
nite
considering the fact that brenspeed's using 39 lb insjectors and a boost-a-pump with their non-intercooled kit to make the same hp that you're shooting for, i'd recommend you do the same, as brenspeed's f/i setup's are tried & true.
then again, i'm sure there are others that have been fine without fuel upgrades. i'm just sayin, i wouldn't chance it.
Old Apr 26, 2010 | 01:56 PM
Pony123's Avatar
Pony123
thats exactly what i scared of .. seeing if anyone has the same setup
Old Apr 26, 2010 | 02:16 PM
Blacksmoke's Avatar
Blacksmoke
The Paranoid One
This comment made no sense at all after his reply to you.
You are scared of seeing if Brenspeed has the same setup?
I'm sorry but I cannot tell what in the hell you are trying to say.
Are you trying to say you are scared of running your setup when NO ONE else has your setup? That would make more sense to me.
As of now all I can say is.. errrr.... um... what?
Old Apr 26, 2010 | 02:48 PM
Pony123's Avatar
Pony123
lmfaoo you had me lol at work....
he said people are running it with stock fuel pump and injectors ..
i said im scared of doing that ...
Called up vortech they said stock pulley is 3.8 that should put me at 8 psi . They advised me to go with bigger injectors
Old Apr 26, 2010 | 02:56 PM
OSUTX440's Avatar
OSUTX440
Run bigger injectors and get a BAP....I think if Brenspeed runs it...you should be fine.
Old Apr 26, 2010 | 03:11 PM
Pony123's Avatar
Pony123
You have about the same numbers as me what are you putting down?
Old Apr 26, 2010 | 04:50 PM
sactown's Avatar
sactown
Thanks for the info
Get the injectors, if you don't whomever tunes your car is not going to be thrilled that you don't have them. Also get at a minimum a BAP, I personally would go with the dual gt pumps. You should also look for an intercooler for the SC, on a hot day at WOT the SC is going to generate a lot of heat, and you want to keep your inlet temps as low as possible, heat is your enemy. Other than that have fun!
Old Apr 26, 2010 | 06:33 PM
OSUTX440's Avatar
OSUTX440
Well, after we let it cool down, it put down 416hp, but after it got hot, w/o an intercooler, it dropped like a rock, I think it finished around 370.
chrisdbassplayer
Oct 13, 2015 06:53 PM
treesloth
Sep 28, 2015 07:03 AM
col2560
Sep 25, 2015 08:59 PM
