Differential
Old Jun 6, 2010 | 10:58 PM
UsedToBeDodge's Avatar
UsedToBeDodge
Default Differential
sorry for so many posts...I'm just trying to find out as much about these cars as possible so I can hit the ground running...I've got the modding fever since I had my Charger...anyway
Whats the differential for the 05 GT...is it a posi-rear? if not is there anyway to switch the differential to get a posi-rear? in otherwords, does a stock GT only have one wheel producing power instead of both rear wheels...my Charger had a posi-rear and I'm really hoping this car does too...
Thanks
Old Jun 6, 2010 | 11:21 PM
REDBOSS1's Avatar
REDBOSS1
Thanks
I believe it does have only one wheel pushing because when I stomp it and get in the power band my *** always goes to the left and the car takes a slight right lean.
Old Jun 7, 2010 | 06:05 AM
dysan's Avatar
dysan
It does have a posi rear in it. I'm about to have mine re-built with the FRPP clutch packs that are used in the GT500. They are a bit stronger than the ones used in the regular GT.
If you are getting a 1 wheel burn, the clutch packs most likely need to be replaced.
Old Jun 7, 2010 | 09:00 AM
jz's Avatar
jz
All GT's have a Limited Slip differential.
mtgldr
Feb 3, 2024 09:00 PM
Boostaddict
2.3L Eco-Boost Tech
Nov 24, 2015 06:11 AM
UrS4
Oct 3, 2015 06:23 AM
KingRando
Oct 2, 2015 08:06 AM
Sep 16, 2015 07:53 PM
