Grinding & missing 3rd!
Old Jun 19, 2010 | 11:12 AM
johnnyv8's Avatar
johnnyv8
Default Grinding & missing 3rd!
Last night while racing @ atco, I notice that my car is really hard to shift from 2nd into 3rd and its now grinding into 3rd (when racing). I really hope I didn't F my tranny up. I have a B & M shifter that I'll be installing soon. I also came across this : http://www.cheperformance.com/CartGenie/prod-208.htm
Just wondering if anyone has ever used one or any advice would be appreciative?
Old Jun 19, 2010 | 11:55 AM
157dB's Avatar
157dB
Cut & Paste Expert
That will do it along with some poly bushings for the OEM shifter.
The new shifter should get the grinding out of the picture
but the damage has already been done??
Old Jun 19, 2010 | 12:05 PM
Soldier GT's Avatar
Soldier GT
The exact same thing happened to me. Went to the track and could not shift into 3rd gear.. Then it started grinding going into third. Found out it was my syncros, which translates into getting a new transmission. My tranny lasted for about 6 mths before if totally went out.
Old Jun 19, 2010 | 01:19 PM
candymanjl's Avatar
candymanjl
yup, same thing here when I went to the track, unless I shifted slow 3rd gear was a PITA. I already had the hurst shifter and it still hung up.
a member on here suggested adding the CHE K-member brace with the limiters and that made everything perfect, haven't missed a shift since!
Old Jun 19, 2010 | 01:26 PM
ShaneM's Avatar
ShaneM
I'm not expert and i dont know if this was an issue in the 06 versions, but this was a known issue with some 05's. Basicalyl the remote shifter and torque makes the 2-3 shift very hard. The TSB on the 05's added torque limiters to the car to eliminate the issue. When running hard my 10 is very hard to shift from second to thrid as well. We have had this same discussion among the 10 owners too. The consensus is that either a k-member with torque straps or a short sifter will fix the issue. Can you shift withotu issues just driving around? If you crunch all the time i say tranny issue, if only when racing or near redline i say its the torque issue.
Old Jun 19, 2010 | 04:20 PM
gman73's Avatar
gman73
Another victim of missing 3rd at the track. Out of 7 runs I missed 3rd three times. I am not sure if the heat had anything to do with it, but when the weather was cooler I did a little spirited driving on the street to test the 2nd to 3rd shift and there was no problem. This Monday, I will order a CHE K-member with a torque limiter. And Wed I am having new clutch and flywheel installed.
Old Jun 19, 2010 | 05:27 PM
candymanjl's Avatar
candymanjl
I didn't notice the problem until I went to the track and was trying to shift as quick as possible. basically when the motor is twisted from the torque your shifter isn't aligned anymore and you get hung up in the gate. the limiters fix that.
like ShaneM said if it's a problem during normal driving too then it's a bigger problem than the limiters could fix.
Old Jun 20, 2010 | 12:44 AM
johnnyv8's Avatar
johnnyv8
Only when I race or WOT does 3rd give me problems. Driving around town, the car shifts fine. I also notice their two different type of K-members, one being a "competition" k-member.
I suppose I will order these and pray it fixes my issue.
Old Jun 20, 2010 | 01:22 AM
Snakebite64's Avatar
Snakebite64
3rd gear sucks stock (o5gt) mind you I have not noticed it on the 09
Old Jun 20, 2010 | 06:51 AM
candymanjl's Avatar
candymanjl
I think the competition one doesn't have poly bushings so you would get more vibrations but the motor would move less.
mine is an '09 and it does it, didn't notice until the track though.
