Not so Cold Air Intake
Old 06-22-2010, 09:05 PM
UsedToBeDodge
UsedToBeDodge's Avatar
Default Not so Cold Air Intake
So the mustang I bought a few weeks ago has a BBK Intake on it, and after running the car the intake gets to be very friggen hot...any ideas why? maybe would a new CAI of a different brand be more effective? or maybe some header wrap?
Thanks in advance
UsedToBeDodge is offline
Old 06-23-2010, 01:05 PM
UsedToBeDodge
anyone?
Old 06-23-2010, 01:15 PM
ski
ski's Avatar
Actually, even at idle rpm the inlet air travels so fast thru the CAI that it doesn't have sufficient time to absorb any heat from the CAI.
That said, if the CAI felt hot to the touch after stop and go driving, then check it after driving on the open highway. If it gets only slightly warm, then you're good to go. But if it's still hot after a few hwy. miles, then you can always install header wrap.
ski is offline
Old 06-24-2010, 07:27 AM
dagamore
dagamore's Avatar
my 2 cents, if you are pulling the air from under the hood, vs in the fender like on the SN95's, you are not getting any real cold air, you would be shocked at how high the under hood temps in stop and go traffic ar.
dagamore is offline
Old 06-24-2010, 08:32 AM
Nuke
Nuke's Avatar
Don't sweat it (no pun intended). Even outside air at typical summer ambient temps won't make enough measurable difference to make rerouting worthwhile. the "C" in CAI is definately a misnomer.
Nuke is offline
Old 06-24-2010, 10:24 AM
siggyfreud
siggyfreud's Avatar
Should me MCAI or Moderately cooler air intake.
siggyfreud is offline
Old 06-24-2010, 10:25 AM
ffk_pennywise
ffk_pennywise's Avatar
+1 for not worrying about it. I have a BBK as well, and it too gets hot to the touch. I would think any CAI would. I still made good numbers on the dyno though.
ffk_pennywise is offline
Old 06-24-2010, 10:26 AM
ski
ski's Avatar
FWIW, Bullitts and 2010+ GT's always pull in outside air, even when standing still at idle, and all GT's pull in outside air at speed.
ski is offline
Old 06-24-2010, 12:36 PM
157dB
Cut & Paste Expert
157dB's Avatar
If its a metal tube, then its normal.
Thats why plastic CAIs rule.
They dont absorb heat nor do they retain it as bad as a metal CAI.
157dB is offline
Old 06-25-2010, 09:09 AM
ski
ski's Avatar
Datalogging results posted on another forum showed that the stock intake IAT's got hotter than any CAI, and it's all plastic.
Also, CAI's with plastic intake tubes got as hot, and sometimes hotter, than CAI's with metal tubes.
ski is offline
Quick Reply: Not so Cold Air Intake
