Delete plates when installing Procharger??
Old Jun 29, 2010 | 08:03 PM
Nitrod86GT's Avatar
Nitrod86GT
Default Delete plates when installing Procharger??
So if I am going with a centri, that will start making power around say, 3K (centri guys step in here) will it matter if I install delete plates? I am going with a D-1SC procharger. Seems like it wouldn't matter so much unless I am running a twin screw. You guys opinions? Steeda Economies fine? What's the going price now a days?
Old Jun 29, 2010 | 08:06 PM
MELLOWYELLOW06's Avatar
MELLOWYELLOW06
I was planning as to do this as well but for some reason didnt. I would love to see reasons to do this mod. Seems simple enough as long as the value is there.
Old Jun 29, 2010 | 08:23 PM
stealth_GT's Avatar
stealth_GT
I did mine before the blower and got some really good results (instant throttle response, some mid-top end increase) Overall, I liked the gains and really should have done them sooner. Kinda hard to tell with the Vortech on, but I'd rather have them on, than not. The stock charge motion plates are a restriction! You'll understand once you see for your own eyes lol.. you'll wonder why they even put them there in the first place!
Old Jun 29, 2010 | 08:55 PM
tx_zstang's Avatar
tx_zstang
Removing the delete plates opens up the intake passage a little more, less restriction to air flow under boost.
Old Jun 29, 2010 | 09:02 PM
Nitrod86GT's Avatar
Nitrod86GT
Are the steeda economy ones they used to sale basically stock plates with the holes filled up? or are they port matched in some way?
Old Jun 29, 2010 | 10:26 PM
ronniegibson1978's Avatar
ronniegibson1978
with as much air as the centi is pulling thru, i'd definitely use the delete plates...whats another 100 if you already got 3500 to 4k in a blower
Old Jun 29, 2010 | 11:04 PM
Nitrod86GT's Avatar
Nitrod86GT
Call me cheap but I dont see the con of filling the stock ones unless the steeda economy deletes are the same size ports? Seems pretty foolproof? Any nightmare stories?
Old Jun 30, 2010 | 02:23 PM
ronniegibson1978
i purchased mine on ebay for like 85 shipped...it was the same ones they used on the 5.0L saleens that they bored over the4.6L. no way would i pay over 150 for them...but at $89 i couldnt complain...and they really did help out alot..more than i expected
Old Jun 30, 2010 | 02:31 PM
MELLOWYELLOW06
I might just have to do it now
Old Jun 30, 2010 | 04:39 PM
Simon1's Avatar
Simon1
When I switched ot he delete plates with FI I had some low speed, decel surging. You may experience it or you may not. I had a turbo so it was slightly different.
Youmay consider a before and after approach. They are really easy to replace and retuning should be a snap. Give it a try and see what they do on the car and if you are happy, don't change. Or change it later just to see.
