engine pinging... again
Old Sep 19, 2010 | 06:47 AM
Sirsilent's Avatar
Sirsilent
Default engine pinging... again
Hi,
I got Brenspeed tune package about 1.5 years ago. The first time I got it my engine started pinging and Brenspeed sent me another tune which fixed it... until now. 1.5 years later it suddenly started again. At 4000 rpm and higher my engine starts pinging. What can be the cause of that suddenly?
Old Sep 19, 2010 | 07:12 AM
jhawkr's Avatar
jhawkr
Have you changed where you get gas? Usually, pinging is caused by too low octane. I would advise you to put in a better grade or change where you buy gas for awhile and see if it goes away.
Old Sep 19, 2010 | 01:21 PM
HypromanGT's Avatar
HypromanGT
+1 on potential bad gas; also run some seafoam and see what happens.
Old Sep 19, 2010 | 01:28 PM
BruceH's Avatar
BruceH
Originally Posted by Sirsilent
Hi,
Carbon deposits from unburned gas. Caused by using too high of octane for the tune. It takes awhile and over time enough carbon builds up to reduce combustion chamber volume and increase compression ratio.
Try the seafoam.
Old Sep 20, 2010 | 07:19 AM
Nuke's Avatar
Nuke
All good suggestions above. If your tune was fine and the pinging began recently, I'd suspect the octane level or your engine and NOT the tune. You may also want to reset the adaptive learning (disconnect the battery for about 20-30 minutes) and reload the tune but I suspect it's either the gas or carbon buildup as stated above.
Nick Oliver
Oct 17, 2018 04:22 AM
AmericanMuscle4.6GT
Nov 10, 2015 02:06 PM
rksnow1
Sep 14, 2015 08:46 PM
TfcCDR
Sep 14, 2015 12:08 PM
Pyrate Dave
Sep 10, 2015 07:30 PM
