Engine PCM code problem
Old Dec 6, 2010 | 10:13 PM
Cooter's Avatar
Cooter
Default Engine PCM code problem
Hi guys. Back a couple of years ago. I had an accident with a cup of coffee from Starbucks. I knocked a cup over into my passenger seat that happened to have my programmer sitting in it. Well I had to send my programmer back to SCT because it really screwed it up. At the time I had the Demolet 93octane tune in the car. It wiped out all the codes installed in the SCT programmer including my stock tune.
Well, a little while later I had to take my car back to Ford because of the E-brake sticking in cold weather. I knew the guy in parts and for a small monetary tip, the mechanic re-flashed my computer with a stock tune. I know he had a hard time re-flashing it.
So, my main question about this is- Is there any way I can tell what PCM code he used to re-flash the car?? I've got it the re-flashed code in my SCT-2 now.
I've put my CAI back on the car and it ran pretty bad. So, I put the stock air intake back in.
Old Dec 6, 2010 | 10:26 PM
SpartaPerformance's Avatar
SpartaPerformance
I'm not a tune guy but The X-cal2 has a menu function that reads strategy, your answer may lie there.
Old Dec 7, 2010 | 02:26 AM
Cooter's Avatar
Cooter
Sparta, thanks for the reply. I think I might have found what you're talking about.
The PCM code can also be retrieved using an SCT flash device such as the X3 Powerflash device or SCT XCalibrator 2. To do this, plug the device into your vehicle's OBDII port, located under the drivers side dash (on most applications). Once the device is powered up and sitting on the main menu, scroll down until you see "Vehicle Info" and hit Select. Now navigate down until you see "Read Strategy" and hit Select. Follow the on-screen instructions until the code is displayed, and write it down. Some common Ford strategy codes are "FPASAGE" and "FPAN0U4"
djbigskrilla
Sep 20, 2022 01:04 AM
mstahoo
SVT Forums
Aug 19, 2021 09:15 PM
bryan616fl
Jan 25, 2019 09:07 PM
microgt
Aug 20, 2015 07:12 AM
HIS S-197
Aug 10, 2015 05:47 PM
