Air vents stuck!
Old Jul 24, 2011 | 07:27 AM
ironh19's Avatar
ironh19
Default Air vents stuck!
My fellow Mustang brothers! Lend me your ears, For I have an issue, this morning, I used my defroster to clear the morning condensation from my windsheild, once that was clear I switched the vents to blow towards me, alas, the vents although set to blow towards me are still blowing on to the windsheild, the switch it self seems to be ok, I can turn off the blower and still turn on the max ac with it, but it seems the doo hicky that makes the air direction change is FUBAR. Anyone have an experiance or knowledge of how to fix this?
Old Jul 24, 2011 | 07:32 AM
mapitts's Avatar
mapitts
Blend door actuator. I have also seen the vacuum line that operates the blend door rot, although not on a Mustang. If you select normal AC or the floor does the door move? I just thought after I posted for a minute. I need to see if the blend door is electrically or vacuum operated. Sorry.
Old Jul 24, 2011 | 08:37 AM
ironh19's Avatar
ironh19
I dont think it does move, just stays on where the windsheild is.
Old Jul 24, 2011 | 11:13 AM
JIM5.0's Avatar
JIM5.0
Funny that your air vents suck. Mine blow
Old Jul 24, 2011 | 11:38 AM
ironh19's Avatar
ironh19
mine blow too, just in one direction!
UPDATE: In case some one needs to research this.. I went back into the car, placed the switch back on to the stuck mode, turned the key on to the on position, waited 30 sec, then went to each setting and waited for each transition to complete and its fixed now. Might have just been a gremlin in the electrical system.
Old Jul 24, 2011 | 02:57 PM
drewsky's Avatar
drewsky
glad you got that fixed! that would drive me crazy.
Old Jul 24, 2011 | 06:56 PM
JIM5.0's Avatar
JIM5.0
Then yours both sucks and blows!
http://www.hark.com/clips/zmpsqmbcgm...m-suck-to-blow
http://www.youtube.com/watch?v=ZXOAc5yt218
None the less, seeing that you are in a southern state of the same latitude, I am glad you have solved your automotive HVAC conundrum. Being also in the deep south in a very very hot state (over 100 degrees F every gawddamn day ever since mid April, and not a single day under 100degressF), having an AC that works like it is supposed to is an absolute must
mrtrodonet
Sep 19, 2020 03:12 PM
PaulH2
20
Jan 31, 2016 09:48 AM
Dokilar
15
Oct 16, 2015 08:13 PM
bradleyb
California Regional Chapter
Oct 1, 2015 01:02 AM
1996cobraconvertible
SVT Forums
Sep 30, 2015 02:01 PM
