Another Clutch problem
started about 2 weeks ago. It comes and goes but I'm noticing a high pitch sound coming from underneath the car(i hear it more in the middle by the drivers side) when im releasing the clutch shifting into gear low rpm. I hear it mostly 1st and 2nd gear...3rd, 4th, and 5th no sound. I also hear it when im in second gear low rpm hit the gas hard when the car picks up i hear that high pitch sound once i let go it goes away. I think its the clutch so any help would be appreciated
Thanks
Thanks
Yup I tried that only making noise like I said once in a while when shifting either from 1st to 2nd or 2nd to 3rd. Also when im in 2nd gear and I gun the car at low rpms once the car jerks back when I hit the gas it makes that sound for a second than goes away.
well based on what you have noted, i gotta go with the transmission
as the source of the noise. maybe the thing to do at this point is consider
checking the fluid level or changing it altogether. good luck and i hope
it's something simple that you can fix at home.
