Which CAI?
Old 04-22-2012, 12:30 PM
AdamAV
AdamAV's Avatar
Default Which CAI?
Which CAI is the best for a 05 GT? One that's good even for high hp later down the road.
AdamAV is offline
Old 04-22-2012, 01:06 PM
Nuke
Nuke's Avatar
There is no "best". Paired with a good tune, any CAI will make equivalent power. And without a tune, don't expect more than 3-5 RWHP from a stand-alone CAI and expect to throw a CEL for running lean, even with the no-tune-required CAI's, on occassion. The tune is about 75%-80% of the combo's power gain so be more concerned with whose tunes you buy than with the CAI.
If you read the sigs of the forum members, you'll see a lot of C&L, K&N, JLT, Steeda and a few others dominate. I did a poll not too long ago and roughly 75% of the forum members are running non-OE tunes.
Nuke is offline
Old 04-22-2012, 01:18 PM
AdamAV
AdamAV's Avatar
What about plastic or aluminum piping? Is there one that works better?
AdamAV is offline
Old 04-22-2012, 02:37 PM
Soldier GT
Soldier GT's Avatar
I could be wrong but it seems to me if you have a aluminum cai system it would draw more heat...
Soldier GT is offline
Old 04-22-2012, 04:34 PM
JCON
JCON's Avatar
http://www.wmsracing.com/wmsweb/WMS-...ntake_Ram.html
Go with this one. Better results when moving, backed by datalogging since a dyno can't measure the difference ram air has on a still car. Can run with out a tune and produce better results but the tune is where the money is.
Dyno'ed 23rwhp without a tune (although I would like to see this in person)
I will be getting this intake shortly after my exhaust is installed.
JCON is offline
Old 04-23-2012, 08:09 AM
lawrencecar1
lawrencecar1's Avatar
please advise after install. very interesting..
lawrencecar1 is offline
Old 04-23-2012, 08:49 AM
iceguyb14
iceguyb14's Avatar
Get the newest JLT. I had the series 2 and made 299whp 312wtq from intake, tune, after cat xpipe, and axle back exhaust and that's it on my 2010 with a 92 octane tune from Bama.
iceguyb14 is offline
Old 04-23-2012, 12:37 PM
JCON
JCON's Avatar
I will report numbers after I get in in and dynoed which may be sooner than I anticipated
JCON is offline
Old 04-23-2012, 07:39 PM
AdamAV
AdamAV's Avatar
You have to have a ram air hood in order for that ram air intake to work though, right?
AdamAV is offline
Old 04-23-2012, 09:10 PM
JCON
JCON's Avatar
No. If you look at the revised radiator cover, you will see to large cutouts as well as a larger, square, latch area. These are sufficient to provide the filter with enough air to produce good numbers for just a CAI (with or without tune)
JCON is offline
Quick Reply: Which CAI?
