confused
Old Oct 17, 2013 | 09:51 PM
UsmcMustang's Avatar
UsmcMustang
Unhappy confused
allright guys let me list off my mods and then i tell ya my rwhp and what the cause of such a low number could be
- 5.1 l low compression dish pistons - 13.55
- livernois stage 3 heads
- bbk longtube headers
- high flow cats
- outlaw flowmaster axle back
- saleen stage 4 cold air
- comp cams stage 2 nsr
- 47 lbs injectors
- stock intake
- stock throttle body
- livernois lock outs
- 4:10 gears
allright i got it dynoed it made 321 rwhp , which i think is kinda low , i was wondering if it could be because i have a low compression engine ( saving for kenne bell supercharger 2.8 l and a t - 56 magnum )
i believe that static compression is 9.04 , i could be wrong
if that is the cause anyway to increase the compression without using a supercharger since that one will be out of my reach for awhile since im restoring a 67 pontiac tempest at the moment
again any input is appreciated
Old Oct 17, 2013 | 10:18 PM
UsmcMustang
ps
i had it dynoed back in 2011 minus the injectors and the heads and it made 360 rwhp on a dyno dynamics
the recently one used is a dynojet
i understand you have to take dyno numbers with a grain of salt , on the good side last time it dynoed at 298 and it gained some good amount
Old Oct 18, 2013 | 12:42 AM
JCON's Avatar
JCON
Confused as to what pistons you actually have but yes, running lower compression on a non-boosted car will lower your power. Without heads and pistons you should put down 330-340rwhp. With heads, you should be pushing around 350-360rwhp depending on porting. Nothing really you can do except change your internals again.
Old Oct 18, 2013 | 01:53 AM
danzcool's Avatar
danzcool
Well, yes, lower compression lowers horsepower until you boost it. It looks like a built engine, so have you upped the redline yet? I'd guess that upping it to 7k and changing the throttle body would help a bit.
Old Oct 18, 2013 | 08:58 AM
PNYXPRESS's Avatar
PNYXPRESS
- high flow cats
- 47 lbs injectors
- stock intake
- 4:10 gears
unless Im missing something, it looks like youve done alot to increase airflow thru and out of the engine,but nothing to increase airflow INTO the engine.
headwork, LTs, and cats cant flow air that isnt coming in.
Old Oct 18, 2013 | 03:15 PM
ghunt's Avatar
ghunt
This is kinda unrelated but I'm curious as to why you got ported heads and then used NSR cams?
On that topic, I was looking at Comp's own literature and they show that the Stage 2 NSR cams are down on power to the stock cams clear up to 5000 RPM. Might also be an issue.
Also I really doubt the stock throttle body and intake are a restriction on a non-sc engine.
Old Oct 18, 2013 | 08:33 PM
UsmcMustang
before i got the new heads i had the nsr cams , since i want to go with a blower once i get a new tranny i didnt want to spend money on new cams which i need to replace later anyways , same with the intake and throttle body , the kb swaps all that stuff out
i got probe pistons i know they are dish pistons with - 13.55 cc
Pnyxpress , i just saw what you meant , i figured the supercharger would be the increase and air flow , but i see what you mean , i was hoping the bigger heads and bigger injectors would help increase compression ratio since they can move in more air and fuel
again thank you guys for the input
Old Oct 19, 2013 | 08:47 AM
Nuke's Avatar
Nuke
No mention of who's doing the tuning...
Old Oct 21, 2013 | 10:44 AM
AMWill's Avatar
AMWill
Former Sponsor
I think you're right where you should be with a manual, stock TB, stock intake, and current mods. 9.04:1 compression is pretty low for a N/A engine (until it's boosted at least). With aftermarket camshafts, you're going to have more valve overlap causing an even lower than stock dynamic compression. Regardless how free flowing the top end is, I wouldn't expect big power with that compression. Plus, as I mentioned above, having high flowing cylinder heads and aftermarket cams, you're more limited with the factory intake and TB too.
Personally, I wouldn't worry one bit about the power the engine has made so far. Once you throw the 2.8L KB on there, you'll really see what the engine is designed for. Trust me!
Shane
marc954
Sep 29, 2015 03:05 PM
mungodrums
Sep 28, 2015 05:45 AM
mrappe
Sep 26, 2015 10:16 AM
marc954
Sep 25, 2015 06:48 AM
mungodrums
Sep 22, 2015 08:36 PM
