Timing Chain
Old Feb 12, 2014 | 10:31 AM
Goldenpony's Avatar
Goldenpony
Default Timing Chain
In an S197 (4.6L) that isn't beat on, has oil changed every 5K miles with full synthetic oil, how long should the timing chain last before it should be replaced?
Old Feb 12, 2014 | 11:01 AM
Rudolph Hucker's Avatar
Rudolph Hucker
forever i think
bikes have chains..never needed to change one in my life..has to be better idea that cambelts..had a few of those snap in my time
Old Feb 12, 2014 | 01:45 PM
Derf00's Avatar
Derf00
Gentleman's Relish
It's not the chain that is usually a problem, it's the chain guides. They are typically covered in Nylon (delrin) or made entirely out of nylon to reduce noise/chatter and keep the chains 'on track' when the nylon wears out, you get more noise and eventually the chain will jump a tooth...or two from slack.
If you change your oil regularly you should be fine for the life of the engine on the chain guides and chain.
http://www.shopfreedomracing.com/46L...Z-6M256-CC.htm
Old Feb 12, 2014 | 04:44 PM
SpartaPerformance's Avatar
SpartaPerformance
There is no expected service life attached to Ford OHC timing chains, they get replaced when they start making noise.
Old Feb 13, 2014 | 08:19 PM
JFitz's Avatar
JFitz
So when you eventually get the bug and start rebuilding your engine with forged internals, might as well replace the chain guides and chain.
Old Feb 14, 2014 | 09:07 AM
Scott2's Avatar
Scott2
When you decide to take the plunge I strongly recommend you look into the FRPP 4.6L 3V Camshaft Drive Kit. It has everything you need (including new phaser and bolts) and is available for much cheaper than buying the individual parts, just shop around for best price.
Old Feb 14, 2014 | 08:02 PM
SpartaPerformance
Yes, that is the best complete kit.
Old Feb 14, 2014 | 09:01 PM
Goldenpony's Avatar
Goldenpony
I'm not having any TC problems, I was just wondering how long they last. Out of curiosity, how much does that kit run?
Old Feb 15, 2014 | 05:52 PM
SpartaPerformance
That kit is around $290
mungodrums
Oct 7, 2015 04:01 AM
Golfsito
Oct 6, 2015 11:02 AM
clowe1965
Carolina Regional Chapter
34
Sep 28, 2015 09:18 PM
Sep 8, 2015 11:50 AM
