NA 3V Stroker dyno
Old May 27, 2014 | 10:03 AM
2005Redfire6's Avatar
2005Redfire6
Originally Posted by Ricardo
Your car is making nice numbers. And you are setup for boost later on. Are you going to go with boost later or try to bump up compression?
Gonna leave the compression as-is and probably run nitrous.
Originally Posted by breathegood
Yeah, that torque curve is more broad and flat than a stock 3V. You have no reason to be disappointed in the peak numbers if you are planning F/I. No go pull some stumps!
It does feel like it runs pretty hard!
Old Jun 1, 2014 | 05:20 PM
JCON's Avatar
JCON
The car has potential with that build. My car made 330 rwhp and 336 rwtq on stock block-heads-cams, with intake, UDP, CMDP's, LT, O/R ProChamber, and 4.10's (*and I may have a compression leak).
Do you have the dyno run file you can email me? I have been thinking about stroking (or cams) but want to see a dyno sheet I can compare to mine in the dyno program.
Old Jun 2, 2014 | 06:10 AM
2005Redfire6
That is a lot of power with just those mods.
I need to scan the dyno sheet in and I can do that. If you're talking about the actual file, I don't have that.
Old Jun 2, 2014 | 04:40 PM
JCON's Avatar
JCON
Yeah I was talking about the .drf. The tuner, a mustang specialist, was surprised as well. He said that was about 10-15 more than he expected. He cut the dyno and said it was done making power but at 6k the line was still climbing, not falling (although should have fallen shortly after 6k). Have to do some compression testing but when all is confirmed, I plan to hit a different dyno and see how the results compare.
Old Jun 2, 2014 | 05:35 PM
gmoran1469's Avatar
gmoran1469
Can you post the sheet because if so I am buying some new mods.
Old Jun 3, 2014 | 05:49 AM
JCON's Avatar
JCON
https://mustangforums.com/forum/4-6l...3v-dynoed.html
I had this thread after the tune day but I'll repost the sheet:
The car feels solid and pulls great despite burning oil.
Old Jun 6, 2014 | 12:35 PM
2005Redfire6
Interesting......
Old Jun 6, 2014 | 12:40 PM
gmoran1469's Avatar
gmoran1469
Originally Posted by 2005Redfire6
Interesting......
Yeah, that's what I'm saying. 50 RWHP is a hell of a gain. I've been looking at the mods and I'm wondering how much the CMDP and UP combo would net with the stock exhaust.
Old Jun 6, 2014 | 05:49 PM
moosestang's Avatar
moosestang
Who did the tune? It's a built motor, throw some more timing at it!
Old Jun 6, 2014 | 10:45 PM
JCON's Avatar
JCON
The guy who tuned it was surprised. I can only guess that the intake really is a cut above the rest of them and some how my slightly ported and polish stock TB helped. After I figure out this compression issue, I plan to hit a different dyno than it was tuned on and see how consistent the numbers are.
Would really like to hit a track this summer.
