Lean Bank Error
Old 08-06-2014, 10:58 PM
wyliedx
wyliedx's Avatar
Default Lean Bank Error
I bought a brand new 2014 GT and got a CAI w/ bama tune. I installed the CAI and installed the tune and after the first day I got the 171 & 174 errors. I returned the car to stock to check if it was the tune and the error re-appear within the first 5 miles driving. Since then I have re-installed the tune and I bought a can of starter fluid and check all the connection areas and tubes and i'm not getting in change the mustang's idle. I just pulled the main tube out and re-installed, checked all the connections and all plugs. The check engine light is still on.
When I drive the car 1st and 2nd gear are really rough and if I let off the gas it drives like its about to die but it doesn't.
Any ideas
wyliedx is offline
Old 08-06-2014, 11:18 PM
JCON
JCON's Avatar
Clean the MAF. It's possible when you changed intakes something got on it and is giving bad readings. Are you clearing the codes after reading them?
JCON is offline
Old 08-07-2014, 09:21 AM
Slowbra302
Slowbra302's Avatar
Try loading one of the other 3 tunes. If they are the same, try re-downloading the tune and pushing it to the car. The tune could have corrupted in the email transfer or device transfer. If all that fails, have them email a fresh copy. If that doesn't resolve, data log the tune and send the log file in for them to analyze. They will get you squared away man.
Slowbra302 is offline
Old 08-07-2014, 10:38 AM
dslpow3r
dslpow3r's Avatar
I just got my Tuner as well, with the custom tunes. However have been hesitant about flashing the car, afraid that the same thing may happen to mine. I have a similar setup however my CAI doesn't require a tune. Please post what you find in case I have the same issues, when I decide to run a custom tune.
dslpow3r is offline
Old 08-07-2014, 06:17 PM
wyliedx
wyliedx's Avatar
I just got the cleaner for the maf and I will update.
wyliedx is offline
Old 08-08-2014, 08:45 AM
AMDanBailer
Former Sponsor
AMDanBailer's Avatar
Any ideas
^ Let us know how this goes. This is an odd issue since the car is brand new. If it's happening on both the tuned file and stock file it's clearly something mechanically wrong.
Keep us posted! Worst case you could swing the car over to the dealership.
-Dan
AMDanBailer is offline
Old 08-09-2014, 10:39 AM
wyliedx
wyliedx's Avatar
So it appears that I got the MAF dirty when I was installing the CAI. I clean the MAF and cleared the code. I've driven the car only about 10 miles since then, (waiting on the Hurricane in Hawaii) but no problems. I will be putting some miles on it today and I will update it.
wyliedx is offline
Old 08-09-2014, 08:51 PM
Warrio17
Warrio17's Avatar
Sounds like what happened with me. Bama sent me the tunes based off an incorrect ECU code. I contacted Bama, explained what was going on and they adjusted the tune. Runs great now
Warrio17 is offline
Old 08-10-2014, 03:29 PM
dslpow3r
dslpow3r's Avatar
Sounds like you may have it worked out, thanks for the update. I have decided to wait till I hit 10K, I figured if anything happens to my car due to an factory assembly issue it should do it by then.........hopefully. I know some dealerships are mod friendly, but dont want to take a chance with the dealer thats nearest to my house and wind up with an expensive paperweight.
dslpow3r is offline
Old 08-10-2014, 06:20 PM
wyliedx
wyliedx's Avatar
So after driving it for a day, the light and codes are back.
What fun.
Trying to update my tuner and get new tunes.
wyliedx is offline
Quick Reply: Lean Bank Error
