08 ford mustang gt turbo
Old 12-14-2018, 09:02 PM
Alberto Flores Cardenas
Alberto Flores Cardenas's Avatar
Default 08 ford mustang gt turbo
Can a 2008 ford mustang gt handle 4 turbos??
Alberto Flores Cardenas is offline
Old 12-15-2018, 01:27 AM
Dino Dino Bambino
Dino Dino Bambino's Avatar
The biggest problem is finding enough space to install them.
Dino Dino Bambino is offline
Old 12-15-2018, 01:33 AM
2 in the engine and 2 by the exhaust
Old 12-15-2018, 05:14 AM
danzcool
danzcool's Avatar
The real question is why? Just for bragging rights or car shows? Sure it can handle it, but they would need to be tiny in order to be able to spool up. For drag racing a lot of guys go with 1 big turbo.
The thing that will be tricky is that the exhaust manifolds and headers that are available collect all 4 exhaust ports on on each side of the engine giving you 2 exhaust gas feeds, you would have to do custom fabrication to get 4 pipes from 2 cylinders each and it would be best to consult the firing order to choose the 2 cylinders to combine that will give the best performance & scavenging.
If the engine is stock then you'll want to keep boost pressure around 10-11psi (which can easily be accomplished with a small single turbo), if the engine is built then let'r rip and go for it if that's what you want.
danzcool is offline
Old 12-17-2018, 12:18 PM
Derf00
Gentleman's Relish
Derf00's Avatar
Simple answer, sure.
The complicated one, what are you trying to achieve and how much money you got?
Derf00 is offline
05-24-2014 02:14 PM
rich_anzik
4 Cylinder NA and Turbo
05-20-2008 02:41 AM
WhitePony02
03-29-2008 03:11 PM
rocknrolloutlaw
02-04-2006 03:33 AM
IAmFreakinGreat
12-12-2005 06:17 PM
Quick Reply: 08 ford mustang gt turbo
