Handling Performance Any questions about suspension, steering, tires, or rims can be asked here!
track pack wheels
Old Nov 22, 2009 | 08:46 PM
mr.shift's Avatar
mr.shift
Default track pack wheels
Any body know if the track pack 19" wheels are the same as the optional 19" GT wheels offset etc.
Also would the GT 18" wheels fit or would the brakes on TP be in the way.
TIA
John
Old Nov 22, 2009 | 08:57 PM
10BlackGT's Avatar
10BlackGT
Yes they are the same wheels as the optional 19 inch premium painted wheels. Anything 17 inches and above will fit.
Old Nov 22, 2009 | 09:30 PM
Kona6Stang10's Avatar
Kona6Stang10
I want 19's really bad
Old Dec 21, 2009 | 07:19 PM
JaggedEdge's Avatar
JaggedEdge
How wide are these 19" wheels
Old Dec 21, 2009 | 07:23 PM
6+6 Stang's Avatar
6+6 Stang
245/45/19 8.5 " rims, i believe
Old Dec 21, 2009 | 07:25 PM
Hoofprint's Avatar
Hoofprint
I believe the tires on the track pack vehicles are 255's
Old Dec 21, 2009 | 07:33 PM
6+6 Stang's Avatar
6+6 Stang
Performance options? Just one. The nicely named Track Pack. For $1,500 it adds a unique set of dampers, a front strut-tower brace, a shorter 3.73:1 axle ratio, a limited-slip differential, dual-piston front calipers with performance brake pads, recalibrated stability control, a set of cast-aluminum 19-inch wheels with 255/40ZR19 Pirelli P Zero summer performance tires, plus several pieces from the current Shelby GT500, including its front and rear antiroll bars, rear lower trailing links and front upper strut mounts.
Old Dec 22, 2009 | 12:54 PM
6+6 Stang's Avatar
6+6 Stang
10Black....??? I was reading that if you went with 14.5 " Rotors you have to have at least 18 " I'm trying to get this straight by next year......I have 19's now, the 2010 GT Premium comes with 12.5 " rotors up front and 14.5 " on rear or is it 12.2 and 14.2? I want to upgrade wheels and tires next year and I actually want to go 18' but when I do the wheels I want to put the Baer Cross drilled 14.5's all the way around, will a 18 " support that or have to go 19 or 20's? Nuke...Way in if you can?
Oct 7, 2015 07:02 PM
mungodrums
Oct 7, 2015 04:01 AM
mungodrums
Sep 28, 2015 05:45 AM
Sep 8, 2015 11:50 AM
