wierd buzzing after shifting
for some reason, sometimes after i shift, i hear a wierd buzzing noise immediately after, when i drive my brothers mach, his does it too but a little less noticable, have anyone of you had this problem? i dont no if its specific to machs or not, i just wanna make sure its not a big problem
Does it sound like gearwhine? Do you have an aftermarket shifter?
I know since I put on my MGW I can hear alot more transmission noise, and when I get on it I can gear the gears, or when I am turning heavily at slow speeds.
I can almost guarantee you that it is the throw-out bearing. Every one is different and mine, in particular, will buzz between shifts due to the release of the bearing from the pressure plate allowing it to freely spin along its roller bearings. Nothing to it, you get use to it.
My $0.02
My $0.02
think I hear the same thing. Is it usually right after shifting and at a reasonably low RPM? Sounds like in the trans or toward the front? I was thinking I was tearing my clutch up. The throw out bearing theory will work for me I guess, oh well.
