Mach 1 Section This section is for discussions relating to the reincarnation of the Mach 1 trimline.
Wheel Spacers
Old Oct 22, 2007 | 01:14 PM
cesar5571's Avatar
cesar5571
Default Wheel Spacers
I recently purchased a pair of Maximum Motorsports 1" wheel spacers. The directions say that under certain applications, some of the stock lugs will have to be cut off with a grinder so the wheel will sit flush. Has anyone ever installed these on a stock 03/04 Mach 1 with stock wheels (rear only) and if so, have you had to cut the stock lugs?
Thanks!
Old Oct 22, 2007 | 01:21 PM
xx9gt6xx's Avatar
xx9gt6xx
Default RE: Wheel Spacers
Had some 1.25" on my 96 GT. Fit just fine, but if you pulled out of a driveway wrong or got that rear end to flex funny that rear fender loved to bite that tire. My tires were chewed up like a mother. If your car isn't lowered you should be okay but if it is then I'd stay away from the spacers...
Old Oct 22, 2007 | 01:34 PM
cesar5571's Avatar
cesar5571
Definitely not lowered. Completely stock. I just want the rear wheels to protrude a bit more, mostly for looks. I am not interested in cutting the lugs, and will get wider wheels if necessary. Spacers just seemed to be the best way to do what I wanted.
Thanks for the info!
Old Oct 22, 2007 | 01:47 PM
xx9gt6xx's Avatar
xx9gt6xx
No prob... You should be alright. What size tire?
Old Oct 22, 2007 | 01:55 PM
cesar5571's Avatar
cesar5571
They are the stock wheels: 17 x 8-inch Magnum 500-style "Heritage Style" (5 spoke). I love the looks of them, and they do make wider aftermarket replicas if the spacers do not work out.
Old Oct 22, 2007 | 04:24 PM
nikbait's Avatar
nikbait
What's the point in making your tires stick out further than what they should be? Is it just cuz its supposed to look cool...
Old Oct 22, 2007 | 04:38 PM
cesar5571's Avatar
cesar5571
Cool has nothing to do with it. That would imply that I care what others think about how it looks. I like it.. that's all that matters.
Old Oct 22, 2007 | 05:30 PM
xx9gt6xx's Avatar
xx9gt6xx
I had 275's when they would bite the fender on my GT. If you have 245's w/ stock suspension w/ the spacers you'll be good to go
Old Oct 22, 2007 | 05:58 PM
nikbait's Avatar
nikbait
Oh ok well I was just wondering...
Old Oct 22, 2007 | 06:34 PM
Mach1Fox's Avatar
Mach1Fox
I put them on my stock '03 Mach 1 and had no problems.Ilike the look of them also. The wider stance looks good and is a lot cheaper than buying wider wheels.
