Mach 1 Section This section is for discussions relating to the reincarnation of the Mach 1 trimline.
mach 1 hood??
Old Oct 25, 2007 | 05:56 PM
1995svtcobrawr's Avatar
1995svtcobrawr
Default mach 1 hood??
i have a 2003 mustang gt and i got a shaker system for it and im not gonna cut my original GT hood to stick the shaker throught it so im about to buy a OEM replacement mach1 hood for it and i was wondering if it would fit on my mustang?
Old Oct 25, 2007 | 07:17 PM
Stone629's Avatar
Stone629
Default RE: mach 1 hood??
I am totally guessing here, but I would say yes. I would ask someone about itFord dealer body shop to make sure....ask more than one body guy though.
Old Oct 25, 2007 | 07:27 PM
MACH5IVE's Avatar
MACH5IVE
It should easily fit!
Old Oct 25, 2007 | 08:47 PM
HamMach1's Avatar
HamMach1
Lot's of people do the Mach 1 shaker/hood conversion and have had no problems.
Old Oct 26, 2007 | 06:44 AM
wakin3722's Avatar
wakin3722
I would say yes.The best thing to dois call the manufacture from whom you are buying the hood and ask them if the hood would fit a 03 GT they should be able to tell you.
Old Oct 26, 2007 | 12:07 PM
TheOneThatLasts's Avatar
TheOneThatLasts
Throw some cobra badges on it, a saleen kit, and a roush sticker across the top of the windshield too. That will look super cool.
Old Nov 2, 2007 | 08:44 PM
LynnBob Mustang's Avatar
LynnBob Mustang
ORIGINAL: TheOneThatLasts
Problem???
The hood should fit fine, it is the mounting of the shaker that may be the problem. The stock GT hood is lower then the MACH hood. If you got the CDC shaker scoop, you may have to find a way to raise the scoop.
Lynn
Old Nov 2, 2007 | 09:37 PM
jmac72187's Avatar
jmac72187
corner carver
ORIGINAL: LynnBob Mustang
Problem???
Lynn
+1
The Shaker isn't going to sit at the right height for the Mach hood. It is designed for the lower GT hood.
Old Nov 3, 2007 | 02:35 PM
LynnBob Mustang
Here is CDC's Shaker mounting system, two rails attaching from the alternator to throttle cable attachment on the Plenum, throttle body.
Shaker mounted
I'm not sure how the real MACH's are hooked up or the reason why they are taller the standard GT's.
I'm assuming the 4V engine itself is taller as well as the plenum and throttle body being taller then the stock GT, thus the need for the higher hood.
So as I stated, you'll have to figure out to get the scoop higher so it goes out the MACH hood.
Lynn
Old Nov 4, 2007 | 12:07 AM
HamMach1's Avatar
HamMach1
Shaker mounted
Lynn
Wow that looks ugly as hell [:'(]
From the outside, I thought the conversion kits looked pretty cool but ZOMG @ that inlet tube from the Shaker scoop to the filter [:'(][:'(]
