Mach 1 Section This section is for discussions relating to the reincarnation of the Mach 1 trimline.
Supercharging??
Old Oct 27, 2007 | 07:35 PM
03_svt_cobra_22's Avatar
03_svt_cobra_22
Default Supercharging??
i got a 04 mach 1 with 14K on the speedo, from a single ower yadda yadda yadda neways the questions are...
will the 03 cobra eaton fit on the mach 1?
if so... ill put the 8:8:1 compression pistions in it, but will the aluminium block hold up to the stress?
and does the mach 1 have forged internals?
Old Oct 27, 2007 | 09:27 PM
HamMach1's Avatar
HamMach1
Default RE: Supercharging??
The Eaton will fit.
And if your Mach is a manual it has a forged crank but nothing else.
If your Mach is an automatic then it has nothing forged.
Old Oct 28, 2007 | 10:01 AM
xx9gt6xx's Avatar
xx9gt6xx
I posted something like this in the SVT section like 4 months ago and basically the outcome was that the whole top and front of the engine has to be redone, a lot of **** has to be re-routed and the cost to doing so would be the same as buying an aftermarket blower...
Old Oct 30, 2007 | 12:41 AM
MACH5IVE's Avatar
MACH5IVE
Its simply alot easier and more beneficial to go with a centri. or twin screw! Eaton's have no where near the potential of some of the aftermarket blowers out there!
Old Oct 30, 2007 | 12:45 AM
MACH5IVE's Avatar
MACH5IVE
And to answer your ?'s! Yes the eaton will fit, but alot of little parts are required. The eaton willbasically top out before you even have to worry about the block, its the internals that you need to worry about which usually top off at 450rwhp, with the exception of the crankshaft if you have a 5-speed!
Old Oct 30, 2007 | 09:55 AM
xx9gt6xx's Avatar
xx9gt6xx
ORIGINAL: MACH5IVE
+1...
Old Oct 30, 2007 | 10:47 AM
5speedstang's Avatar
5speedstang
but the eatons sure are very loud.
Old Nov 5, 2007 | 06:59 PM
jmach1pollack04's Avatar
jmach1pollack04
what little things would you have to change
Old Nov 7, 2007 | 12:55 AM
redbullitt's Avatar
redbullitt
kenne bell it unless you get an eaton for free lol. Centrifugal would be great too... either way blow it
Old Nov 7, 2007 | 02:04 PM
Furinox's Avatar
Furinox
ORIGINAL: jmach1pollack04
the parts list is like a mile long. you can find it at the mach1registry.
GimpyHSHS
19
Dec 19, 2023 01:12 PM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 09:21 AM
col2560
Sep 25, 2015 08:59 PM
