Mach 1 Section This section is for discussions relating to the reincarnation of the Mach 1 trimline.
Grind
Old Jan 18, 2008 | 12:15 AM
jdpfman's Avatar
jdpfman
Default Grind
I notice in the morning or when the car has cooled down, and i start driving. When I put it into second at around 3g-3.5 a get a bit or a grind. I have put the clutch all the way in and it still does it. Am i doing something wrong?
or should i get it check out? Also when I put it into 3rd it feels like a bit of cracking.. I was told that was normal to feel some cracking...
Old Jan 18, 2008 | 05:45 AM
jmac72187's Avatar
jmac72187
corner carver
Default RE: Grind
This is a common problem with the 3650 tranny. It tends to happen in cold weather. I talked to tremec and they said that the original spec for tranny fluid was too high. It started at 4 quarts of fluid, but it has been lowered multiple times. I think the spec is 3.17 or 3.07 quarts now. I am not positive because I have it written down at home and I am away on vacation.
Just swap the tranny fluid and use the lower amount and the problem should be fixed.
Old Jan 18, 2008 | 05:55 AM
jrherald420's Avatar
jrherald420
Default RE: Grind
really???? ive got to check this out on mine too.
Old Jan 18, 2008 | 06:10 AM
jmac72187's Avatar
jmac72187
corner carver
Default RE: Grind
Yup. You can call Tremec and ask them. I read that it tends to happen to the trannies that are under 40 degrees farenheit.
Old Jan 19, 2008 | 12:00 AM
jdpfman's Avatar
jdpfman
Default RE: Grind
cool thx for the info..
dang.. I am going to take it to the dealer tomorrow.
Old Jan 28, 2008 | 11:48 PM
jdpfman's Avatar
jdpfman
Default RE: Grind
ORIGINAL: jmac72187
yo jmac72187
so is it 3.17 or 3.07??
Old Jan 28, 2008 | 11:53 PM
MACH5IVE's Avatar
MACH5IVE
Default RE: Grind
If you plan on taking it to the dealership so they can do the fluid change for you dont! They'll just rape you on a job you can do in 20 minutes by yourself with simple tools!
Old Jan 29, 2008 | 12:12 AM
MACHJUAN's Avatar
MACHJUAN
Default RE: Grind
yeap the tr-3650 is crap mine does that too and it even squeaks when its really could and i romp on it getting on the highway
Old Jan 29, 2008 | 05:20 AM
jmac72187's Avatar
jmac72187
corner carver
Default RE: Grind
ORIGINAL: jdpfman
ORIGINAL: jmac72187
yo jmac72187
3.17 according to Tremec.
Old Feb 10, 2008 | 02:05 PM
crazyone's Avatar
crazyone
Default RE: Grind
Did it work ?
