Mach 1 Section This section is for discussions relating to the reincarnation of the Mach 1 trimline.
resetting the speedometer?
Old Feb 15, 2008 | 09:25 AM
renegadeoffunk0's Avatar
renegadeoffunk0
Default resetting the speedometer?
My speedometer's off by like 2 mph (not really a big deal) but i was wondering if there's a way to reset it. I'm not sure if that trick with the odometer reset button does that (haven't tried it, only read up on it).
Old Feb 15, 2008 | 10:17 AM
jchittick's Avatar
jchittick
Default RE: resetting the speedometer?
Does you car have aftermarket gears?
Old Feb 15, 2008 | 10:41 AM
renegadeoffunk0
No it's all stock.
Old Feb 15, 2008 | 11:08 AM
USMCrebel's Avatar
USMCrebel
Mach I Section Moderator
dont you have to have a tuner to do it with these cars.
Old Feb 15, 2008 | 11:10 AM
jchittick's Avatar
jchittick
You can with a tuner, but not sure why its off if you haven't done anything to it. How do you know its off?
Old Feb 15, 2008 | 11:20 AM
renegadeoffunk0
I've checked it with a gps unit and also those speed limit signs that radar you and show your speed (not sure how accurate it is) but I'm generally travelling 2-3 mph slower than what's indicated on the speedometer at any speed. Also, at 2,000 rpm in 5th, shouldn't the needle point right at 70?
Old Feb 15, 2008 | 11:26 AM
USMCrebel's Avatar
USMCrebel
yes it should be right at 70, those signs are wrong, at least the ones here are about 3-5 mph faster than your actually going. GPS is accurate tho.
Old Feb 15, 2008 | 12:05 PM
renegadeoffunk0
So what does turning on the car while holding the odometer reset button do? Is it some kind of diagnostic mode or something?
Old Feb 15, 2008 | 12:18 PM
USMCrebel's Avatar
USMCrebel
it doesnt do anything cept trip reset. i always do it when i fill up on gas.
Old Feb 15, 2008 | 12:44 PM
jchittick's Avatar
jchittick
ORIGINAL: renegadeoffunk0
If you search, you might be able to find it. There is a diagnostic or something like that but only works on 99-00 Mustangs if my memory serves me...
