Mach 1 Section This section is for discussions relating to the reincarnation of the Mach 1 trimline.
Is it normal?
Old Apr 1, 2008 | 04:50 PM
stang1101's Avatar
stang1101
Default Is it normal?
To spin my tires all the way through 1st and some of 2nd. How do I get more traction!? I'll be going at like 3k rpm in 1st, hit it and I just spin shift 2nd and spin more[&:]
Old Apr 1, 2008 | 05:02 PM
MACHJUAN's Avatar
MACHJUAN
Default RE: Is it normal?
easy fix would be some kdw 2s they are great street tires, your spinning becauses its a mach and not a 2v i kid
Old Apr 1, 2008 | 05:12 PM
B.O.B MACH 1's Avatar
B.O.B MACH 1
Get some better tires, and some control arms. It helped me out a bit.
Old Apr 1, 2008 | 05:23 PM
stang1101's Avatar
stang1101
so would you recommend
http://www.tirerack.com/tires/tires....Force+T%2FA+KD
or these
http://www.bfgoodrichtires.com/overv...-a-kdw/22.html
Old Apr 1, 2008 | 06:10 PM
MACHJUAN's Avatar
MACHJUAN
these
Old Apr 1, 2008 | 07:28 PM
stang1101's Avatar
stang1101
whats the difference?
Old Apr 1, 2008 | 10:51 PM
Shaken's Avatar
Shaken
You got that car from a very nice lady named Judy.
Old Apr 1, 2008 | 11:16 PM
B.O.B MACH 1
I would get nitto 555s. They wear great and have good tread wear (for a drag radila) they will hook nice too, but ther a little week in real bad rain and cold weather. I had the Hankook Ventus V4es for a while and i liked them alot.
Old Apr 1, 2008 | 11:20 PM
rygi23's Avatar
rygi23
Dumping more loot on sticky tires and control arms will always do more. Tires have diff feels and grips. Rather than stomping it from the get, learn your tire's tolerance under various rates of gradual load. I've found that trying to perfect this really plants the tires and nets 60' times not far off from drag radials. 2nd gear will always spin some, but if you're not spinning going into the shift you won't get hardly as squirly.
Old Apr 5, 2008 | 08:20 PM
darkmach1's Avatar
darkmach1
cheap fix???? dont floor it in first.but then again every now and then is good to loose control.
