frustrated with my car
i need some advice. i havea 2004 mach 1 and it has 44,000 miles on it. a month ago i lost 5th gear, don't ask me how. i had a new tranny put in and three weeks later it lost 4th gear and sounded like marbles rolling around when it is in neutral. i took it back in and the the guy said i have a miss in my motor that caused my tranny to go out like it did. i argued with him and the owner over this for a week. could my motor have caused it? also i am now running rich. how do i fix that. my check engine light has never came one once since i have owned the car. i have a strong strong exhaust smelleverytime i crank it. does anyone have some thought one these things?
a miss won't cause a trans failure, and if you had a miss it would turn on the light and throw a misfire code. also if you are running too rich it should also throw a code for fuel system too rich. on cold startup sometimes you will smell a stronger exhaust smell untill the pcm goes into closed loop and the cats start functioning. hope this helps.
ORIGINAL: cengland
2)that right there says he's a damn idiot.
3)it could be several things.....need to have the stock tune reflashed, fuel filter change might help, may have bad injectors.
ORIGINAL: cengland
my car never completely lost any gear. the problem i had out of both trannies was when i started to speed up i would here a whining noise going from first to second. then in fourth gear it wopuld go into gear fine, but after it was in gear it would grind real bad. i argued with the company until they finally put a new tranny in, but they are sticking to the story of my motor being the problem. they told me flat out they wouldn't fix it again even though my new one is under a warranty. that is fine cause the next time it goes out i don't want them to touch my car. thanks guys for the input. i love mustangs, but i don't know how to work on cars. i work on multi million dollar aircraft for the USAF.
ORIGINAL: cengland
+1 on not using them again.
92 5.0stang
Aug 13, 2015 06:46 AM
Milan Dragway
Aug 12, 2015 03:43 PM
