Mach 1 Section This section is for discussions relating to the reincarnation of the Mach 1 trimline.
Air Filter Change...
Old May 8, 2008 | 09:19 AM
STMPDE's Avatar
STMPDE
Default Air Filter Change...
Is it easier to remove the air duct from the shaker hood leading to the air box to remove the air filter? Does it just slide in? I don't have to worry about that one on my GT, but was wondering regarding my sons Mach. It's a pain enough on mine, knew you guys would know.
Old May 8, 2008 | 09:24 AM
USMCrebel's Avatar
USMCrebel
Mach I Section Moderator
Default RE: Air Filter Change...
no, it's a lot harder IMPO to remove the whole intake from the shaker. just undo the piece of junk clamping the intake box otgether and change it that way.
Old May 8, 2008 | 09:34 AM
STMPDE's Avatar
STMPDE
So, to be clear, there's enough flexibilty to leave it connected to everything except at the clamped position? Do you Mach guys also remove the snorkel in the fender well? I didin't know if it would affect the ratio of air coming in through the hood scoop.
Old May 8, 2008 | 09:39 AM
USMCrebel's Avatar
USMCrebel
yeah, take the snorkel out. once you unhook everything, it'll be a cake walk. It wont affect the airflow from the shaker.
svfetter
Oct 5, 2015 11:39 AM
Explosive
Oct 2, 2015 07:45 AM
fastbackford351
Oct 1, 2015 12:24 PM
RCS02v6
Sep 29, 2015 01:46 PM
Sixer4Life
Sep 28, 2015 07:05 AM
