Mach 1 Section This section is for discussions relating to the reincarnation of the Mach 1 trimline.
car wont crank
Old Jun 27, 2008 | 07:43 AM
cengland's Avatar
cengland
Default car wont crank
my car stopped cranking out of nowhere. i had drove it to work yesterday and then my wife took it to the doctor. i was cleaning the garage so when i was done i went to pull my mach in the garage and it wouldn't crank. it turns over and the battery and all is working fine. my fuel pump comes on. me and a friend opened a fuel line behind the intake and tried to crank it and there was no gas. could there be a fuse problem? can anyone help with this?
Old Jun 27, 2008 | 08:49 AM
DesertMach's Avatar
DesertMach
Default RE: car wont crank
You said the pump comes on but yet is there a fuse, this confuses me.
Fuel filter?? do you have fuel pressure before the fuel pressure regulator it sounds like you checked for pressure after the regulator. If you are sure the pump is coming on I would pull the fuel like by the fuel filter, this should tell you weather its the pump, filter, or regulator depending on where to find the lack of pressure. but I'm not sure about where the fuse is, wether its a fuse in the fuse box or a relay under the hood.
Old Jun 27, 2008 | 10:45 AM
USMCrebel's Avatar
USMCrebel
Mach I Section Moderator
this is definately a pressure issue, check the fuses start with the cheap stuff first!
Old Jun 27, 2008 | 10:56 AM
Derf00's Avatar
Derf00
Gentleman's Relish
ORIGINAL: cengland
If the pump turns on It's highly doubtful (impossible) it's a fuse. I say change the fuel filter. If that's not it, you're probably looking at a new fuel pump because either the diaphram broke or the screen in the tank is jacked.
Edit: You're also a little confusing; Turning over means it cranks. You're saying it cranks but won't catch/fire...correct?
Old Jul 1, 2008 | 05:20 PM
cengland's Avatar
cengland
thanks for the replies! i found out a day later why my car wont crank. it went into anti theft mode. i got it to crank but now i have a strong fuel odor and smoke from the back end of the car. also now my power steering pump went out. my car has 47,500 on it and never raced never drove hard.well it gets drove hard once in a while. for the most part i take excellent care of the car.
mstahoo
SVT Forums
Aug 19, 2021 09:15 PM
mirandaandjimmy
Nov 16, 2015 08:51 AM
microgt
Aug 20, 2015 07:12 AM
92 5.0stang
Aug 13, 2015 06:46 AM
Milan Dragway
Aug 12, 2015 03:43 PM
