Mach 1 Section This section is for discussions relating to the reincarnation of the Mach 1 trimline.
Nitrous vs SC?
Old Aug 24, 2008 | 10:52 PM
nikbait's Avatar
nikbait
Default Nitrous vs SC?
Ok, so am looking into putting either a nitrous kit onto the mach 1 or saving up for a sc. Which would be easier/cheaper to do and which one would keep the engine safer?
Old Aug 25, 2008 | 10:47 AM
USMCrebel's Avatar
USMCrebel
Mach I Section Moderator
cheaper will be the N20 in the short run, but the long run it will be safer for the S/C, and MUCH cheaper depending how much you spray.
FWIW, you can find used 2.1 KB's for around 2100.
Old Aug 25, 2008 | 10:57 AM
powerfreak's Avatar
powerfreak
nitrous is cheaper, but depending on how much you want to spray, you should also upgrade your fuel system. IMO, nitrous is a waste unless you're going to be seeing time on a track (it does look cool though). A SC will give you power all the time. It will be more work and more $$...and you should also upgrade your cooling system.
Old Aug 25, 2008 | 01:11 PM
nikbait's Avatar
nikbait
Yeah, that's what I was figuring, from what I've read. Well, I guess its savin up for the SC, and upgrades
Old Aug 25, 2008 | 02:00 PM
powerfreak's Avatar
powerfreak
I think SC is the way to go...after you do, every time you drop the hammer, you'll be a happy camper.
Old Aug 25, 2008 | 03:11 PM
Furinox's Avatar
Furinox
If you don't mind buying used I'd do that. I bought a complete vortech t trim kit for 2k. It was on a car for 400 miles then they wanted more power so went turbo. You just gotta shop around a jump on a deal when you see it.
Old Aug 25, 2008 | 03:22 PM
jmac72187's Avatar
jmac72187
corner carver
I would do nitrous if you are going to the track a lot. It will get pretty pricey if you are filling your bottle all the time on the street.
Old Aug 25, 2008 | 03:50 PM
nikbait's Avatar
nikbait
Problem is, I would have to save up for the SC kit...and do not know what all is involved in putting one on. Oh well, guess all I can do is wait lol.
Sandmanbjj
Aug 21, 2015 12:38 PM
mstngdvr17
Dec 25, 2003 04:55 PM
jhogan2424
Nov 5, 2003 08:51 PM
67gt500
Aug 17, 2003 04:01 AM
