Mach 1 Section This section is for discussions relating to the reincarnation of the Mach 1 trimline.
question about missing
Old Nov 15, 2008 | 09:38 AM
cbest1223's Avatar
cbest1223
Default question about missing
I have a 04 mach1 and yesterday when I got in it I noticed it had a miss at idle and lower rpms. I ran two tanks of 87 octane in it but last night filled up with premium. the car jumps at a crusing speed of under 80 but if you get on it the car runs fine. kinda feels like your in to high of a gear and need to down shift. any suggestions or anyone had this problem with the fuel.
Old Nov 15, 2008 | 11:41 AM
rygi23's Avatar
rygi23
Read the section of your manual regarding what type of fuel needed to run. Never run any fuel under 91 octane, and get accustomed to which station's gas is 92 and which is 93. There isn't a $ diff between the two, stick with 93. I can't tell you the 87 octane was the cause of the miss, but it I were a betting man I'd bet on it. The entire motor's set up is computer calibrated for premium gas. Fuel injectors can suffer with the improper octane, and one of the audible symptoms of that is a miss...hence the sound. Start with putting only 93 in it for a couple/few tanks, then work your way up from there.
Old Nov 15, 2008 | 01:04 PM
cbest1223's Avatar
cbest1223
thanks i will run a few through it and let you know what happens
Old Nov 15, 2008 | 01:12 PM
rygi23's Avatar
rygi23
Cool, good luck man.
Old Nov 15, 2008 | 01:32 PM
Mustang3GT07's Avatar
Mustang3GT07
Why would you run anything lower them premium in your car? Doesn't it say on your dash premium fuel only?
Old Nov 15, 2008 | 01:58 PM
grif62's Avatar
grif62
They do lol
Old Nov 15, 2008 | 02:06 PM
rygi23's Avatar
rygi23
Okay take it easy on a brother! Yup, he should've known. I still talk to some, performance car owners included, who think the higher octane is "recommended" and don't realize that anything less will actually do damage. Don't put him down, help him. The lessons we learn with experience.
Old Nov 15, 2008 | 02:19 PM
Mustang3GT07
I'm not trying to put him down or be mean in anyway, Sorry if I cam across as that way. Just remember to read your manual and it should say on your dash premium fuel only.
Old Nov 15, 2008 | 03:08 PM
jmac72187's Avatar
jmac72187
corner carver
High compression or boost requires higher octane. My friend used to have a Turbo Saab. Nothing special performance wise but it still was pushing boost. He though that the "Recommended" meant that he only needed to use higher octane if he wanted more performance.
Old Nov 16, 2008 | 11:56 AM
cbest1223's Avatar
cbest1223
I only have had the car for a week and was only looking at the speedo not the writing around it. lol I am going to go ahead and change the plugs today and get a code reader. I had them run it last week and it was the o2 sensors but it came back on . Just wanting to make sure it dosent say anything else. It still bucks and jumps at a crusing speed but runs perfectly fine when you stomp it. knida like when you are just barely pressing the gas. I will let you know how it comes out. Thanks for the info.
