Mach 1 Section This section is for discussions relating to the reincarnation of the Mach 1 trimline.
Would this setup run lean?
Old Jan 23, 2009 | 03:03 PM
darkmach1's Avatar
darkmach1
Default Would this setup run lean?
Looks like I'll be going to the track towards the end of Feb. and I wanted to have a couple things installed by then. I already have K&N FIPK (installed), I also have the o/r prochamber (not installed yet) and I was debating ordering the LMII catback. Now according to the link below, the K&N with pretty much any catback will run somewhat lean, but I will also have the prochamber to add to that and this might cause a leaner condition. Can anyone, that has dynoed their car, confirm that the intake/midpipe/catback combo will run too lean for comfort? Would running higher octane (100LL) prevent detonation? The reason I ask is because even when stock, I had the car dynoed to get a baseline, on the third run it was pulling timing at high RPMs.
http://www.magnaflow.com/05news/magazine/mach1.asp
Old Jan 23, 2009 | 03:24 PM
USMCrebel's Avatar
USMCrebel
Mach I Section Moderator
it shouldn't cause it to run to lean at all. I don't know though. i might be letting you know soon though
Old Jan 23, 2009 | 03:31 PM
darkmach1's Avatar
darkmach1
^ thanks rebel, according to the link, it runs between 14.0-16.0 below 3k and goes down to about 13.0 from 3k-redline.
Old Jan 23, 2009 | 03:36 PM
USMCrebel's Avatar
USMCrebel
and thats your dyno now?
14-16 is to lean for me.
Old Jan 23, 2009 | 05:13 PM
03MachMe's Avatar
03MachMe
i have the K&N FIPK, o/r H, and flowmaster weld ins and my dyno car was right around 12-13 the whole time. so i think you should be fine
Old Jan 23, 2009 | 07:05 PM
darkmach1's Avatar
darkmach1
sounds good, just to be careful I'll dyno the car when I get these parts installed that way I can see how lean it is before taking it to the track.
BTW, what did you put down with those mods? If you don't mind me asking.
Old Jan 24, 2009 | 12:07 AM
03MachMe's Avatar
03MachMe
290/311
Old Jan 24, 2009 | 12:42 AM
darkmach1's Avatar
darkmach1
290/311
nice, I don't think I'll make that, I might make ~285/305, because I put down 268/291 stock.
Old Jan 24, 2009 | 05:26 PM
USMCrebel's Avatar
USMCrebel
Don't trust a dyno man. track times rule the streets.
Old Jan 24, 2009 | 07:48 PM
03MachMe's Avatar
03MachMe
how is 8.2 in the 1/8th then with those mods?
