Mach 1 Section This section is for discussions relating to the reincarnation of the Mach 1 trimline.
Forged Internals?
Old Feb 14, 2009 | 11:17 PM
sIx's Avatar
sIx
Default Forged Internals?
Alright guys, I'm not sure if this is in the right section or not... I'm debating a Mach or a GT, but I have a few questions...
I heard that the '03/04 Mach 1s have the same motor as the termi, just not supercharged? Is this true? How much power will they handle?
Thanks for any info..
Old Feb 15, 2009 | 09:01 AM
livefast1's Avatar
livefast1
if the machs manual it has a forged crank if its auto it has a cast crank. a termi has mahle forged pistons (alrite but not made out of the best material) and forged h beam rods. machs have powdered rods and hyperutectic pistons. i believe the cams are different too but not 100 percent on that one.
Old Feb 15, 2009 | 11:08 AM
sIx's Avatar
sIx
Thanks, what kind is the max the motor could handle safely?
Old Feb 15, 2009 | 11:10 AM
Mach1man's Avatar
Mach1man
You definitely heard wrong. The poster above is correct, manual car = forged crank, automatic = cast crank and lower redline.
About the only thing the stock Mach 1 motor shares with the Terminators is the heads.
As far as power, the Mach 1 stock block can handle a good amount. But if you're looking for over 500 rwhp, the cracked powder rods and pistons will start looking for a way out!
Old Feb 15, 2009 | 03:50 PM
GTRACER88's Avatar
GTRACER88
450 RWHP just like the GT's.
Old Feb 16, 2009 | 12:08 AM
USMCrebel's Avatar
USMCrebel
Mach I Section Moderator
yeah
450-500rwhp depending on tune a usage of a meth injection kit.
def go with a mach the gt is just a ****ty platform, and 5k-70k machs are gt price range.
Old Feb 16, 2009 | 08:46 AM
03MachMe's Avatar
03MachMe
cams are the same
Old Mar 31, 2009 | 09:27 PM
o2jayjay's Avatar
o2jayjay
wasn't your question "which one is better a mach 1 or gt?" well like said before a mach 1 manual is better. handles more power. mach 1 are dohc which means great head flow and very responsive to upgrades. all around great car. idk what the tranny can handle but if you can get your hands on a mach then lucky. for pistons and rod at a good price go to mod max racing(google) and you find all you motor parts in a good price range. good luck and i hope i helped.
Old Mar 31, 2009 | 10:43 PM
rygi23's Avatar
rygi23
cams and heads are same
cobra- cast iron block, low compression, forged, 1000 hp
mach- alum. block, high compression, unforged except crank in manual, 500 hp
Old Apr 4, 2009 | 10:26 AM
xxkazp3rxx's Avatar
xxkazp3rxx
Mach is much better then the GT... power limits are the same, but much easier to get there with the mach, and it has a lot more on the tach...
Speaking of which I do have one for sale
