Mach 1 Section This section is for discussions relating to the reincarnation of the Mach 1 trimline.
Battery Relocation
Old Apr 22, 2009 | 01:15 PM
machracer11's Avatar
machracer11
Default Battery Relocation
So has any body on here used a battery relocation kit? what is the point and is it worth it? i figure its for a bit better weight balance but does the battery really make that much of a difference or is it for looks/more room in the engine bay?
Old Apr 22, 2009 | 06:51 PM
rygi23's Avatar
rygi23
The point is 1) weight distribution, 2) better traction, most effective mounted over the passenger side tire where the majority of torque is sent. I considered it myself until learning that at most drag strips an external shut-off switch is required for tech inspection. I really don't think it's enforced for street looking stangs though, depends on your track. For the above reasons, the new Dodge Challenger actually comes with the battery mounted in that exact spot.....not fair, man.
Old Apr 22, 2009 | 08:56 PM
hot wheels's Avatar
hot wheels
also to make room for a vortech aftercooler
Old Apr 22, 2009 | 11:03 PM
machracer11
So what exactly is an external shut off then because that would definitely be something that I would need to work out
Old Apr 24, 2009 | 04:10 AM
jmsjags's Avatar
jmsjags
there's a switch on the outside of your car that can be used to disable the battery in the event of an emergency
BOB ROME
Jul 26, 2023 01:54 PM
4cylinderplus2
Oct 9, 2020 07:45 PM
baddog671
Jul 26, 2016 01:20 PM
flash_xx
Oct 16, 2015 07:23 AM
logan409
Sep 26, 2015 07:43 PM
