Mach 1 Section This section is for discussions relating to the reincarnation of the Mach 1 trimline.
transmission/ rearend question
Old May 24, 2009 | 02:49 PM
Fstanggt96's Avatar
Fstanggt96
Default transmission/ rearend question
Hey, looked at an 04 mach 1 a minute ago and it had a kinda humming noise whenever you would let off the gas. Is that common or a problem? The car has 44k miles so...
Old May 25, 2009 | 10:30 AM
03MachMe's Avatar
03MachMe
might have aftermarket gears sometimes if not insalled perfectly they will have a little whine. thats the only thing i can think of without hearing it
Old May 25, 2009 | 11:48 AM
Fstanggt96's Avatar
Fstanggt96
Ok thanks for your input. Decided to buy it anyways even if it is a problem. Getting it on Tuesday since the banks are closed today
Old May 25, 2009 | 04:00 PM
Mach1man's Avatar
Mach1man
I agree with the above assessment, it's probably a gear whine. They don't necessarily have to be installed wrong to whine, some gears just whine more than others. Richmond gears can whine like a sumbitch, even if installed correctly!
Old May 25, 2009 | 04:31 PM
03MachMe's Avatar
03MachMe
good deal post up some pics once you get it!!
Old May 25, 2009 | 07:23 PM
USMCrebel's Avatar
USMCrebel
Mach I Section Moderator
what rpm are you @ while at 70mph
Old May 25, 2009 | 08:33 PM
Fstanggt96's Avatar
Fstanggt96
Test drove again, I had it backward. Doesn't have aftermarket gears. When your in a too high of a gear at too low of a speed it does it. Stops when you push in the clutch. Best way i can describe it is if you have ever run a lathe in a machine shop. Makes a similar sound when the machine is just running. My dad thinks its the ring and pinion either having too much play or not enough. couldn't be too expensive to fix would it? I figure for 12.5k it is worth it what do you think? Has 44k miles, brand new 275/40/17 and 245/45/17 tires(2 sets), adjustable suspension( I cant remember what kind), k&n cai, Flowmaster cat-back.
Old May 25, 2009 | 10:24 PM
rygi23's Avatar
rygi23
Man, are you in for a world of fun. I'm sure you've done your research on the differences between it and your GT you just sold. It's your judgement as to if it's worth diving into the rear. If it's only doing it when you're in too high of a gear it may be worth leaving it alone. But only you would know how annoying it is to you. If you ask me, $12.5 is a great price. A big congrats to ya and be sure to post some pics.
Old May 26, 2009 | 01:31 AM
03MachMe's Avatar
03MachMe
if you do decide to get it and go diving into the rear you might as well just put some 4.10s in there while you are at it. you will not be disapointed but good luck what ever you decide
Old May 26, 2009 | 12:01 PM
USMCrebel's Avatar
USMCrebel
+1 it'd cost the same either way
