Mach 1 Section This section is for discussions relating to the reincarnation of the Mach 1 trimline.
P0358 code?
Old Sep 20, 2009 | 12:02 AM
grif62's Avatar
grif62
Default P0358 code?
Engine service light went on, checked the code and it showed P0358. Any suggestions?
Old Sep 20, 2009 | 12:58 PM
grif62's Avatar
grif62
no suggestions?
Old Sep 20, 2009 | 01:17 PM
hot sauce's Avatar
hot sauce
P0351 Through P0360 - Ignition Coil A through J Primary/Secondary Circuit Malfunction
Description:
Each ignition primary circuit is continuously monitored. The test fails when the PCM does not receive a valid IDM pulse signal from the ignition module (integrated in PCM).
Possible causes:
Open or short in Ignition START/RUN circuit
Open coil driver circuit in harness
Coil driver circuit shorted to ground
Damaged coil
Damaged PCM
Coil driver circuit shorted to PWR
Old Sep 20, 2009 | 05:43 PM
watman02's Avatar
watman02
is that the only code or do you have misfire codes as well? if you can figure out witch coil is setting the fault i would swap it to another cyl and see if the fault fallows the coil if so buy a coil
Old Sep 20, 2009 | 06:03 PM
grif62's Avatar
grif62
thats the only code that popped up. I need to check the coils. If I need new coil what would u brand recommend and while im at it what spark plugs u guys recommend.
Old Sep 21, 2009 | 10:05 PM
USMCrebel's Avatar
USMCrebel
Mach I Section Moderator
stock OEM is the best replacement, all the others seem to hate our cars.
Old Sep 21, 2009 | 10:26 PM
grif62's Avatar
grif62
you think I should change the spark plugs while im at it or not. Also I need the location of coils lol.
Old Sep 21, 2009 | 10:42 PM
USMCrebel's Avatar
USMCrebel
if your doing it, you might as well do the whole shabang ya know.
Plugs
wires
coils
airfilter
Old Sep 22, 2009 | 11:35 AM
grif62's Avatar
grif62
where are the plugs and coils located. Also what plugs u recommend?
Old Sep 22, 2009 | 07:39 PM
grif62's Avatar
grif62
well went to a friend of mine, we switched out the coils and plug. Code kept reading
p0358, my hand held tune wouldnt delete it so we went auto zone to delete it and it did. But I think im either going to switch out the coils and plugs or go to car max since i still have warranty. Do u think my intake will void the warranty?
