Mach 1 Section This section is for discussions relating to the reincarnation of the Mach 1 trimline.
Check engine light but no problem?
Old Nov 27, 2009 | 03:03 PM
  #21
2004 V6 3.9's Avatar
2004 V6 3.9
Originally Posted by cwf340
no 7 and 8 are the rear 2 cylinders on the left side. you only need the left side head. unless you just want to replace both.
well fords doing it under warranty so they can replace both lol
Old Nov 28, 2009 | 06:44 AM
  #22
cwf340's Avatar
cwf340
cool, nothin better than free stuff!! esp. when its 4k-5k worth of engine work!!
Old Nov 28, 2009 | 02:34 PM
  #23
2004 V6 3.9
what do you think caused it in the first place? just a defect or from beating on it bc it only has 36,000
Old Nov 28, 2009 | 08:01 PM
  #24
cwf340's Avatar
cwf340
If I was to guess, I would say cheap valves. UPDATE! I contacted ford and got you the answer. The coolant flow through the right side cylinder head was insufficient causing the exhaust valves to overheat and burn. The coolant passages and flow were redesigned to prevent this concern.
Old Dec 1, 2009 | 06:44 PM
  #25
JDraper's Avatar
JDraper
That's a very common problem with the Mach's (and the Cobra's). Affectionately know as "The Tick". There are several companies that make a cooling modification kit that can prevent that from happening again. D'Agostino Racing, EvenFlow and APS all make the kits.
Old Dec 7, 2009 | 08:48 AM
  #26
2004 V6 3.9
your awesome lol, thanks for all the help. So i just got it back from ford and it just started ticking again :/ then the service engine light came back on but it does have more pick up now... eerrrrrr have to bring it back..
Old Dec 9, 2009 | 06:03 PM
  #27
cwf340's Avatar
cwf340
ugh.. that sucks, hope they can fix it right the second time..
Old Dec 10, 2009 | 01:15 PM
  #28
Mustang3GT07's Avatar
Mustang3GT07
Do the "Even Flow Head Cooling Mod", cobra and mach's are known to have the problem and the head cooling mod helps prevent this from happening.
http://www.lethalperformance.com/03-...ng-mod-p-16949
Old Dec 12, 2009 | 08:36 AM
  #29
2004 V6 3.9
Im bringing it back on Tuesday heres the codes its running now:
P1000 moniter check- something like that
P300 random mult misfire
p0301 misfire
p0302 misfire
p0303 misfire
p0307 misfire
p0308 misfire
Old Dec 14, 2009 | 06:44 AM
  #30
cwf340's Avatar
cwf340
jeez, looks like the tech didnt know what he was doing...
