Mach 1 Section This section is for discussions relating to the reincarnation of the Mach 1 trimline.
DTC codes...
Old Dec 14, 2009 | 09:51 PM
Fstanggt96's Avatar
Fstanggt96
Default DTC codes...
I just installed longtubes and a catted x pipe and bought an SCT tuner. I cleared the codes twice now and they keep coming up. Is there a way to turn them off for good?
Old Dec 15, 2009 | 07:14 AM
Shaken's Avatar
Shaken
First off what are the dtc codes? Though there is a good chance you will need a custom or better yet a Dyno tune to correct your issues. Moving the o2 sensors farther downstream I bet could cause some drive ability issues.
Old Dec 15, 2009 | 10:41 PM
Fstanggt96's Avatar
Fstanggt96
Ill update when I plug in my tuner and read them but two say that they are stuck lean, and I believe the other two say they are not working at all(because they are not plugged in). I bought ARH Longtubes and a catted x pipe from LMPerformence and they sent me the wrong O2 sensors(I had to modify them to get them to plug in) and only sent me two. I need all four right? Isn't there a way t just turn them off and not have to worry about it anymore? I'm calling them tomorrow and figuring out whats going on.
Old Dec 16, 2009 | 10:22 AM
Shaken's Avatar
Shaken
Get your hardware corrected clear your codes drive it. I am still pretty sure you will have some drive ability issues because of the primary o2's are farther downstream.
You could only benefit from a dyno tune with your new mod.
Old Dec 16, 2009 | 12:31 PM
Fstanggt96's Avatar
Fstanggt96
What driveability issues Could I have, besides the catts bottoming out on large speedbumps lol? So far its runnig fine and Ive drivin it almost 100 miles. Im going to get the right hardware and probably have it dyno tuned shortly. In the mean time, AM is writing me a canned tune. LMP should have sent me all 4 sensors though right? I only modified the sensor extension they gave me if that was a missunderstanding. The fitting on their sensor ext. didnt match my plug in. I didnt moddify the headers/midpipe at all.
Codes are:
P1000} This is just saying that the system check failed due to the following 4 codes.
Front sensors:
P0141} HO2S sensor circut malfunction (The shop had to moddify the sensor plug ins that LMP gave me)
P0161} HO2S sensor circut malfunction
Rear sensors:
P2270} These two are reading because they are not plugged in because LMP didnt give me extendors.
P2272}
Old Dec 16, 2009 | 01:08 PM
cwf340's Avatar
cwf340
those codes are HO2S sensor circuit malfunction codes, P0141 and P0161 are for the upstream sensors and p2270 p2272 are for the cat monitors. I would suspect they are crosswired or something along those lines. I would also suspect they are reading lean and sending a zero volt signal to the pcm. they are either the wrong sensors or you could have a pinched wire somewhere. all of the o2 sensors share a power feed. I would start by checking the vpwr circuit to the sensors. you should have 12 volts between the vpwr and sigrtn circuits with the key on. if not check the harness for opens and shorts. if you had the trans out, check and make sure the harness didnt get pinched at the top of the bell housing when it was put back in.
Old Dec 16, 2009 | 07:57 PM
rygi23's Avatar
rygi23
man, you're scaring me. Hope I don't run into that crap.
Old Dec 16, 2009 | 10:11 PM
mikedeuce6's Avatar
mikedeuce6
Unhappy
Right!? All of this for headers and a few horses!? Whatever happened to calling up Jegs with a couple hundred bucks and few short hours later youve slapped on a set of Hedmans and are grinning ear to ear on the drive to the exhaust shop? Im almost afraid to mod my Mach at all now. Do I need a dyno tune for a K&N filter too? Sheesh!
Old Dec 17, 2009 | 01:30 PM
Shaken's Avatar
Shaken
Codes are:
Front sensors:
Rear sensors:
P2272}
Actually all these codes except p1000 a rear sensors. P0141 Heated O2 Sensor Heater Circuit Malfunction (Bank 1, Sensor 2) P0161 Heated O2 Sensor Heater Circuit Malfunction (Bank 2, Sensor 2)
http://diablosport.com/index.php?nam...ewtopic&t=9937
This quotation is the best explanation I have seen. Ask who ever you decide to take your car to that supports you hand held.
"With long tube headers, an adjustment to the "O2 transport delay" sub-category is recommended. This accounts for the increased distance from the exhaust from the heads to the front O2 sensors".
http://www.mach1registry.org/forums/...14&postcount=4
Old Dec 17, 2009 | 04:14 PM
rygi23's Avatar
rygi23
Are you saying this is a common hurdle w/ installing LTs? Haven't heard of this stuff before. I want to put the exhaust on, hook up the o2 extensions and be done with it. If it ain't gonna be the case I'll sell em, buy an o/r prochamber and MIL elims.
