Mach 1 Section This section is for discussions relating to the reincarnation of the Mach 1 trimline.
2004 Mach 1 rear diff leak...
Old May 21, 2010 | 08:35 AM
mmenser's Avatar
mmenser
Default 2004 Mach 1 rear diff leak...
I was wondering if anyone could verify a few things for me. I have a bad leak coming from the rear diff. on my 2004 mach 1. In the picture, it looks like this is where it is leaking from. What is that? Would that be the pinion seal? Also, how hard is this to replace? Do you have to pull everything, or is there another way? Thanks for any help.
Old May 21, 2010 | 08:38 AM
mmenser's Avatar
mmenser
This is another shot.
Old May 21, 2010 | 10:18 AM
Kenny_k82's Avatar
Kenny_k82
Hmmm... I thought mine was the rear gasket and that it had just got splattered around but I replaced it only to find out it was the pinion seal. I have been told it's the exact same amount of work which means a couple hours tops, or like $140 parts/labor to have a shop do it.
Old May 21, 2010 | 10:19 AM
Kenny_k82's Avatar
Kenny_k82
And fluid/gasket costed me $80 to do it myself so your lookin at about the same.
Old May 23, 2010 | 11:19 AM
JDraper's Avatar
JDraper
That would be a pinion seal leak. You can do it without tearing the rear apart, but you should make sure that you don't mess up the crush washer by over torquing the pinion nut when you put it back on. A cheap way to do that is to mark the nut and the pinion with a scribe line so that you put the nut back exactly where it was before. Too much torque and you can damage the pinon bearing, too little torque and you might leave some room for it to develop play.
Old May 23, 2010 | 11:53 AM
Stone629's Avatar
Stone629
Exactly what JD said.
I over torqued mine on another car a few years ago and messed up the crush washer. Just make sure whoever does it is good at doing gears, rears, etc.
67LimeCoupe
Sep 30, 2015 04:46 PM
Sep 16, 2015 07:53 PM
zachary1988
Sep 4, 2015 03:04 PM
TimeLord101
Sep 4, 2015 09:27 AM
iamgobono
Sep 3, 2015 12:37 PM
