Mach 1 Section This section is for discussions relating to the reincarnation of the Mach 1 trimline.
install help!!
Old Jan 13, 2011 | 06:00 AM
smitty2919's Avatar
smitty2919
OP deff don't go welded, if you ever want to change your setup, you can just unbolt it. If you weld it you need to take it to a shop and pend more money.
Old Jan 13, 2011 | 12:05 PM
954mach1's Avatar
954mach1
magnaflow chambered catback
Old Jan 13, 2011 | 12:47 PM
smitty2919's Avatar
smitty2919
FYI I don't think the regular magnaflows are considered chambered...they are more of a straight through...you can look through the muffler.
Where did you cut your stock catback and how high did you need to get the rear end off the ground to get the magnaflow over-axle pipes in?
Old Jan 13, 2011 | 01:42 PM
954mach1's Avatar
954mach1
I cut the pipes just behind the muffler on both sides and those were the only cuts I had to make. The old exhaust came out very easy and I did spray the bolts on the h-pipe flanges with some liquid wrench, no problems there.
I then took the car off the ramps and jacked up the rear end only about a foot off the ground and there was more then enough room to slide the pipes over the axle. Total install time was maybe two hours at the most. You do not need a lift to do this job and it was the easiest install I have done compared to other cars. The only thing that sucks is I wish I bought some band clamps before the install because now Ive got to take everything apart again to put them on.
Here is a link to the video: http://www.youtube.com/watch?v=KlUDvgUSi1M
I will also post in the exhaust section.
Old Jan 13, 2011 | 03:15 PM
smitty2919's Avatar
smitty2919
You don't need to take anything "apart" to put the band clamps on. Just jack up the rear again and take off the U-clamps, then open up the band clamps and slide them over the pipes, put the bolts through and tightern 'er up!
Sounds good but it got a little distored due to the grear roarrrr ahaha. Good gob!
Old Jan 15, 2011 | 04:22 PM
954mach1's Avatar
954mach1
ok, got the band clamps today from summit and installed them, much better fitment!!
Old Jan 15, 2011 | 04:26 PM
954mach1's Avatar
954mach1
Default Gears and o/r x pipe next week!!!
Sorry, not really a post, I just needed to get some of my excitement of my chest. Just got done talking with my local shop and he is going to do my 4.10 gears and x pipe next week for a great price!
I cant wait, he said its going to really wake the car up!! Anyone think I can get into the high 12's yet?
mtgldr
Feb 3, 2024 09:00 PM
BOBCATJACK
Sep 14, 2015 02:18 AM
Sep 10, 2015 08:39 PM
