Mach 1 Section This section is for discussions relating to the reincarnation of the Mach 1 trimline.
My mach build.
Old Aug 19, 2011 | 03:45 PM
Justinr1001's Avatar
Justinr1001
Default My mach build.
Since i paid it off a few months ago i decided to throw some money at it. The timing set (chains, tensioners or all) is wore out so i will be replacing that. While i am in there its getting either comp XE262AH-114 (106100) cams, set on a 106/110 lobe center. Or some custom cams, I haven't decided yet. The 106100 cams don't require springs, custom bigger ones will. So i'll have to factor in the price difference and weigh the benefits vs costs on that. Its getting 32 new lash adjusters as well, i'm just hoping none of the followers are bad. Its got the head tick, so the heads are coming off and they are getting the guides and seals replaced, performance valve job, decked and ported. The "head cooling mod" is going on too. I've been doing lots of research on the intake, just ported vs. ported short runner, and the concensus is a full length fully ported intake is the way to go on a street car, so thats what its getting. I'm hoping for close to 380-400ish dynojet hp. Also, i said F the bassani mid lengths i had and decided to get these. 1-3/4 stepped to 1-7/8 with 3 inch x-pipe.
While i was at it, i picked up this stuff as well.
Old Aug 19, 2011 | 04:59 PM
WannaBeGearHead's Avatar
WannaBeGearHead
Go Texas!!!
Go with the 106100s installed at 106/110. With those, ported heads and intake and I don't see how you'll have a problem hitting your power goal.
Old Aug 19, 2011 | 09:41 PM
boduke0220's Avatar
boduke0220
get those runners on the intake shortened up a little, that'll help out alot more than you would think
Old Aug 20, 2011 | 08:53 AM
Justinr1001
I pm'd Na svt on M1R and he told to keep it stock length.
Old Aug 20, 2011 | 09:14 PM
WannaBeGearHead
Go Texas!!!
I figured you talked to NA SVT since you said you'd install the 106100s at 106/110. If I was you I would listen to what he says. He's an extremely intelligent person. If he says keep the stock length then I would keep the stock length.
Good luck with your build!
Old Aug 20, 2011 | 11:22 PM
boduke0220's Avatar
boduke0220
oh ok, well yea if you talked to na svt do whatever he says lol
Old Aug 22, 2011 | 01:37 PM
Justinr1001
Yeah i was a bit confused as to why to use the stock length. I figured a 9 or 10 inch runner would have picked up some hp up top. But, i don't know jack about this stuff, so i'm just gonna go with the advice i got from the ppl that do! lol
1BAD3V
Tennessee Regional Chapter
Oct 6, 2016 12:12 PM
jrrhd73must
Oct 2, 2015 09:17 PM
breaking
Oct 2, 2015 01:27 PM
Sixer4Life
Sep 29, 2015 07:03 PM
1BAD3V
Indiana Regional Section
Sep 26, 2015 09:03 AM
