Mach 1 Section This section is for discussions relating to the reincarnation of the Mach 1 trimline.
New owner- clutch problem
Old Jul 30, 2016 | 11:29 PM
sjones1088's Avatar
sjones1088
Default New owner- clutch problem
Hello all. I am the proud new owner of a 2004 Azure Blue mach. Car has 59k, BBK long tubes, OR X, magnaflow exhaust, cobra IRS with 4.10s, aluminum driveshaft, short shifter, SPEC stage 2 clutch kit, MM suspension, CAI, tune, and a set of black chrome fr500s.
If i drive the car normal, the clutch is perfectly fine. However, if i really get on it and shift at a high rpm, sometimes the clutch pedal will stick down to the floor. After a few second of not pushing the gas it will pop back up and catch. I wouldnt think the clutch would be going out, considering a stage 2 should be more than sufficient for my power levels. Is there anything else that could be causing this? The clutch seems to engage at the very top of the range of motion. So when you push it in, it feels real tight from starting, til about halfway down and then it just feels like nothing. I do have a firewall adjuster but have not attempted to mess with that yet. Any insight would be greatly appreciated, thanks!
Old Aug 2, 2016 | 01:26 PM
Camster's Avatar
Camster
The clutch should be grabbing at no less than the midway point.Adjust it and I think your other issue will be cured.
Ayeecole
Oct 17, 2022 07:37 PM
Taiwan Cameron
Mar 22, 2016 09:45 PM
Mead Whippo
Feb 25, 2016 11:09 AM
mohammadkhannj@gmail.com
Feb 21, 2016 03:01 PM
berger035
Jan 11, 2003 12:40 AM
