Mach 1 Section This section is for discussions relating to the reincarnation of the Mach 1 trimline.
Ground in trunk?
Old Aug 29, 2023 | 09:25 AM
crazyone64's Avatar
crazyone64
Default Ground in trunk?
Hi,
Are there any good ground points in the trunk that can be used for caraudio ground wire?
Thanks,
Old Aug 30, 2023 | 08:12 PM
crazyone64's Avatar
crazyone64
Under the rear seats on the seatbelt bolt plate.
Old Sep 2, 2023 | 07:37 PM
Derf00's Avatar
Derf00
Gentleman's Relish
You want to keep the grounds as short as possible. For any equipment in the trunk, there are grounding points that Ford uses for the Sirius radio and Shaker 1000 options. Remove the trunk liner and on the passenger side metal trunk frame there should be a couple of empty threaded holes for bolts that can be used as a ground. If you have factory Sirius xm, the module will be there and grounded to one of the points.. You can add any ground wires to an existing ground or, if none of the grounds are being used, go to home depot and find a bolt that fits to make it a ground.
crazyone64
Sep 6, 2022 08:29 AM
BlondeInAMustang
Jul 9, 2013 09:47 PM
Warpig12354
Jul 11, 2012 07:55 PM
crewchief429
Nov 11, 2007 10:09 AM
STREETRACER86
Archive - Trades & Freebies
Jun 19, 2006 02:02 PM
