Here is my 07 Sleeper
Old Dec 14, 2009 | 03:05 PM
GrnBullitt08's Avatar
GrnBullitt08
Very nice, how do you like the hellion system? I have been looking into putting one on my car.
Old Dec 14, 2009 | 03:31 PM
tkgc's Avatar
tkgc
The 07 3 v heads were a straight up bolt on with the 04 block which is a mmr mod 900. The only difference was the 07 s motor mounts were 3 bolt the 04 s are 4
The hellion kit is ok it has a poor design and back washs the map a lot and the pvc setup does not work as designed
Sorry about this text I am on the blackberry
Old Dec 14, 2009 | 04:45 PM
bestia27's Avatar
bestia27
Very nice!
Old Dec 14, 2009 | 06:00 PM
GrnBullitt08
Sounds like I should stay away from the hellion...
Old Dec 15, 2009 | 10:38 AM
tkgc's Avatar
tkgc
I would not feel quite that way. Just know going in. You will need to address the pcv return hose as it will make your car smoke in high humidity areas. This can be corrected with a catch can. The issue is because under boost you’re not making vacuum but pressure in the crank instead. 2nd and a little more troublesome is the location of the maf it tends to take a back wash if you come off the stupid pedal too quickly.
3rd If like me you use a high vol. oil pump you WILL have to limit the flow with a nos tip the kit is designed to receive the tip with very minor mod.
The good part of a hellion system is it is a straight bolt on. No hacking up your car.
Tec support is weak thought
As far as how it hooks up well let me say I like the way it drives. It acts like a completely stock car until you shower down then I suggests you drive with both hands on the wheel. Which is a lot easier with an automatic!
The car can hold its own. To change tires would be a dead give away
Old Dec 15, 2009 | 12:40 PM
Batenswytch's Avatar
Batenswytch
redneck gamer nerd chick
Awesome car... awesome dyno! And love the sleeper thing you have going there.
Old Dec 15, 2009 | 03:03 PM
RetroGT2006's Avatar
RetroGT2006
Man people must think that its stock and then you completely dick slap them and they are sitting there scratching their heads like wth just happened.. Must be priceless!
Old Dec 15, 2009 | 06:13 PM
WannaBeGearHead's Avatar
WannaBeGearHead
Go Texas!!!
Nice! I would think you did a good job making it look like a sleeper.
Old Dec 16, 2009 | 05:16 PM
tkgc's Avatar
tkgc
Thanks Guys
Believe it or not she is making 503 rwhp with only 11.4 #'s max boost. I have been thru afew motors so I am playing is very carefull for now.
Once there is another short block on the stand I will turn up the boost throw in a little timing lean it just alittle and we will see what kind of #'s we make then
Old Dec 28, 2009 | 12:39 PM
red07Pony's Avatar
red07Pony
Yea that's a sleeper alright!! Bad@ss stang
