Motor Swap Section Tech and Follow-My-Build Threads for members looking to put a different engine in their Mustang
Ground cables
Old Apr 2, 2017 | 11:00 PM
Jc530's Avatar
Jc530
Default Ground cables
Can someone please tell me where all the grounds in the engine bay should be located.. I have a 2000 Ford Mustang gt. 4.6l. Swapped in a new motor but I'm missing a ground to be connected somewhere in the lower part of the engine.
Old Apr 4, 2017 | 07:32 AM
88 orangepeel notch's Avatar
88 orangepeel notch
You can put as many grounds in as you'd like. Extras won't hurt anything. Your just trying to ground everything together.... Mainly engine to frame/body.
I'm old school so I don't think it should be any different on the newer cars.
Old May 26, 2017 | 01:21 PM
Paul Blakey's Avatar
Paul Blakey
There should be a ground cable located behind the drivers side front tire that connects to the engine. its located on the underside of the frame. just check under the big wire harness under the battery. That is the only one I know of besides the ground on the starter. starter is grounded to the motor, motor is grounded to the frame. without the ground to the frame. the car will not start.
You dont need a bunch of grounds. just a good one.
