Mustang II Section The more economy minded, compact Mustangs which were offered from 1974-1978
Rear window slats
Old Sep 23, 2007 | 09:11 PM
horseman54's Avatar
horseman54
Default Rear window slats
I picked up a set of rear window slats this weekend at a swap meet. I think they are for a Mustang II hatchback. Can anyone verify the measurements? The width is 40 1/2" and the length is 30 1/2". There are 7 slats total. There are two small hinges on the top side and on each side at the bottom there is a hole for some type of lock down. If anyone is interested make an offer.
Old Sep 23, 2007 | 10:44 PM
my77stang's Avatar
my77stang
Default RE: Rear window slats
this should really be in the classifieds section, but i will check measurements for you tomorrow as long as i dont forget
Old Sep 28, 2007 | 10:15 PM
Turbo II's Avatar
Turbo II
Afraid they aren't factory II louvres, they have 8 slats and are around 49 1/2" wide at the bottom. I would bet money you have louvres from a 240, 260, or 280Z (the early style), I just picked up a set last weekend thinking they were II louvres, they sure look like them! Your dimensions match. These are made by the same supplier as the ones for Fords (the manufacturer's stamps on the underside of the latches are the same)
Fairly rare itemjust the same, unfortunately won't fitour beloved IIs.
Old Sep 28, 2007 | 10:25 PM
Turbo II's Avatar
Turbo II
double post
67LimeCoupe
Sep 30, 2015 04:46 PM
DreadPirateRoberts
Sep 26, 2015 02:11 PM
wishinsky
Sep 21, 2015 09:48 AM
Sep 16, 2015 07:53 PM
robjh22
Suspension
Sep 8, 2015 12:47 PM
