chip upgrade
Hi and welcome to the forums. The answer to both of your questions are yes. There are a few programmers out there that will give you the ability to tailor your timing by a certain percent and also change your fuel enrichment up or down. You can do so much more than this with hypertech and the predator tuners though!
With most programmers you can even raise your rev-limiter to allow for deeper shifts and even change shift setting for tighter shifts! Moreover, programmers like the predator even have diagnostic scan tools built in which can detect exactly how your car is set up and will tune it to run better with the aftermarket parts you have installed and you can always go back to your factory setting if you wish. Great horsepower add on!
Hope this helps...
Hope this helps...
Boostaddict
Lethal Performance
Oct 1, 2015 08:58 AM
Boostaddict
3.7L V6 S550 Tech 2015 - 2017
Oct 1, 2015 08:57 AM
