Valve adjustment help
Old May 5, 2007 | 03:21 PM
mustanggtlx's Avatar
mustanggtlx
Default Valve adjustment help
Someone please help
I have read everything I can fined on valve adjustment formy 90 mustang gt and I'm still having problems.[]Chilton repair manual states you need to bleed down the lifters. Then adjust the valves in 3 step. (1)TDC on the compression stroke, (2) then rotate the engine 360deg, (3) then 90deg. Ford tech say I don't need to bleed down the valves.Do I need to bleed down the valves? How dose the afect the valve adjustment?
thanks for any help
Old May 6, 2007 | 07:48 AM
93 FHP SSP's Avatar
93 FHP SSP
Default RE: Valve adjustment help
Welcome to the forums!!! Check out the 5.0 section of the forums for some help.
Old May 7, 2007 | 10:31 PM
PennState's Avatar
PennState
Old May 7, 2007 | 10:44 PM
speedjunkie92's Avatar
speedjunkie92
https://mustangforums.com/m_3184741/tm.htm
Old May 8, 2007 | 12:08 AM
creekrat's Avatar
creekrat
There is really no adjustments necessaryin the valve trane if you have factory heads. Torque the bolts down to specified torque and that is it. These style valves are basicly non adj. in stock setup. No need to bleed lifters down
GimpyHSHS
19
Dec 19, 2023 01:12 PM
cr620
Oct 3, 2022 10:18 PM
mrtrodonet
Sep 19, 2020 03:12 PM
UrS4
Oct 3, 2015 06:23 AM
winner99
Sep 30, 2015 07:04 PM
