3 problems?
Old Feb 24, 2008 | 04:31 PM
2001snake's Avatar
2001snake
Default 3 problems?
My brother recently bought a 1998 stang gt but the odometer and speedometer don't work but the rpm's, oil pressure, battery, and fuel gauges work fine. Does he need to replace the entire cluster? Thanks
Old Feb 24, 2008 | 04:32 PM
2001snake's Avatar
2001snake
Default RE: 3 problems?
The clutch on my brother's 98 gt is really stiff and hard to press all the way down. What is the easiest way to fix? thanks.
Old Feb 24, 2008 | 04:34 PM
2001snake's Avatar
2001snake
when the car is put into neutral or down shift as the rpm's lower it will turn off unless it gets rev'd to 2k rpm's. what could this be? thanks.
Old Feb 24, 2008 | 06:39 PM
spence221's Avatar
spence221
hey welcome to the forums!well for the speedo problem check the speedo cable, speedo gear, or wiring. hope that helps!
Seanam
Oct 4, 2015 10:15 AM
mdj89
Sep 23, 2015 08:49 AM
kachuy10
Sep 22, 2015 01:27 PM
stangin1996gt
Sep 21, 2015 11:01 AM
Big Al's 03
Mach 1 Section
Sep 21, 2015 07:59 AM
